Post Info TOPIC: Gas bottles
Gas bottles
Can anyone help with.
Small problem that I might be having with my gas
i had two regulators joined together mounted on the front of the van connecting to the gas bottle
one or both failed so I just went to RaysOutdoors to get another one , but this time just came back with one regulator that screws directly on to the gas bottle with a hose on the end
i can get gas to the stove but I can't get the fridge to work on gas
weather it's the regulator or there might be something wrong with the fridge
I will get it checked out but I thought that I'll ask the question first
any help would be great
thanks in advance
d
KFT
It can take a while to get gas to the fridge after the lines have been open to atmosphere.
There are gas qualified people here who I am sure will give you some good advice
frank
Avagreatday.
This may or may not be of assistance, but I had a problem with the fridge pilot light so I gave it a squirt of compressed air in a can and it was fine after that.
Gary
Frank is on the money...
You need to be a little more patient with the fridge as it only has a very small jet to get the gas through the system..smile
Just keep trying and eventually it will light
oldbobsbus@gmail.com
Thanks guys
I will keep trying
d
Think you need to get a gas fitter to look at
Im not sure but the 2 you referred to is a special set up for caravans
the single is for barbeques etc
If you went to a caravan place you should be able to get the same regulator as you had befor
Thanks Snaper 49
I really thought that it might be some thing like that
I will head into town and grab one in the morning to see how it goes
Thanks to all
d
