SmartBar
Post Info TOPIC: Scangauge 2 Lc200
Scangauge 2 Lc200
can someone please point me in the right direction of where to plug in the scangaige 2 to an LC200 series GXL Landcruiser..
Appreciated
If you lower the steering wheel down . Then your hand up under the dash near the steering column you should find the plug there . Just run the scan gauge wire down the gap .then plug it in hopes this helps
Many thanks and kindly appreciated
PS, easy to see and fit??
All you do is plug it in and follow the instructions .it is a fiddler at first but is amazing what it will do .I got mine just to see fuel per 100 K's water temp and auto trans temp .you will be surprised at the auto trans temp .hope it is helpful
