Post Info TOPIC: pre wire for solar
pre wire for solar
confuse  hi gang fred hi can someone tell me were is the regulator for the pre wire solar on my royal flair on the roof is it near front all side the van is pre wire for solar l got told but l can not see it can someone happy me please
probably hasn't got a regulator at this stage..
just the wire
Fred, it is likely that the pre wired refers to having the wires from the roof down to where the regulator goes already installed. I do not believe it would include a solar regulator charger.
I would expect to find the wiring terminate near where the battery is, if your battery is inside the van, then the position for the regulator is likely to be close to where your power distribution is.
Discovery 4,
Retreat Brampton
thanks gangs
hi gang fred here check the van for solar panles l have not got junction box on roof l got wire inside caravan got 2 black 2 red l think they go with a solar controller everyone now of a good one cheers fred
