Post Info TOPIC: 12v attachment on generator
Hi...
I was wondering if anybody has charged their batteries using the 12v attachment on their generator.   Although I do have a trickle charger attached to the house batteries.....I have in the past flattened my truck batteries and was wondering if using the 12v attachment on my generator would deliver a sufficient charge to eventually start the motor.
Your thoughts would be appreciated.
George
I was told its is a very crude system and un regulated
If you want to charge best plug in a battery charger and do it that way
Yes it will work & most are capable of 8Amps. They are unregulated but if your starting battery is flat it certainly will do the job, just keep an eye on the voltage.
D.L.Bishop
I have charged a dead flat battery this way it took 15 minutes  car started with ease.
Lance C
thank you all for the response, it is good to know that plan B is there....
George
I have read,it's best to plug some type of load into the 240 volt
side,something like a 100 watt light globe,etc,etc,to help regulate
the 12 charging.
Retired Electronics Tech
Amateur Radio Callsign VK2CJO
Thanks John...will keep it in mind.... yes that does make sense...thanks again
George
We have a Honda 3kva. The 12volt attachment charges batteries quickly with no problems.
