Post Info TOPIC: Jayco solar
Jayco solar
Have 2 12v agm 100ah batteries  Do i run feed wires from solar reg to both or just the 1
They are set up parallel confuse
Also circuit breaker size and where to fit them. Solar is 150ah set
Working for the Taxman and the accountant
By parallel I assume you mean the two batteries are connected by positive to positive and negative to negative, then you can have the solar connected to the positive of one battery and the negative of the other battery.  Also assuming the batteries are both the same amp.
Glen
Naturally
Probably a 20 A DC fuse in line, should only need to connect the regulator output to one battery as they are in parallel. Just make sure pos and neg are correct. Be careful, it may only be ELV (12 Volts) but a deadshort can weld the battery terminals and create a big bang.... and thats no theory.. (pun intended)
Safe travels
Live long and Prosper
