Post Info TOPIC: Kitchen drain clearing?
Hi everybody, I tried to find some advice about this on the "search" system but failed. no
The kitchen sink is emptying more slowly, and I'm starting to wonder if "something" might be stuck down there. I've always been careful to wipe anything fatty off with paper towel before washing up. Its a very simple drain to the outside, and we put a bucket under it.
Would it be wise to put a hose upwards (covering the sink first! eyepopping.gif ) or use "Draino" or similar?
Would appreciate advice, thanks. smile
Cheers,  Gerty. ... at home
Hi Gerty , you can try hot soapy water to loosen it or Bi Carb Soda , presuming the drain has a grate it is more likely just build up over time rather than a larger blockage . be carefull in back flushing as crap may go everywhere if majorly blocked and lets go.
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
Once a week I pour a kettle of boiling water down the sink. Seems to be enough to keep my drain running freely.
Sue and Phil
Our sink drain becomes blocked from time to time and I now carry a short handled plunger, it is a wooden handle with a rubber cup on the end that you place over the plug hole and push down on vigorously with water in the sink it works immediately to clear the blockage.
David
David
 As I found out the hard way - do not try this if you have a shower outlet as well!
There is a Bunnings product that is a type of enzyme cleaner for the general gunk that build s up in pipes and grey water tanks. I cannot remember its name but it comes in a purple container. Someone else may know name?
wendyv
Put bi-carb soda down the drain then pour white vinegar on it - it will fizz up and will help to clean the drain. Hope this helps.
Where there is a will there is a way!!
Ours got blocked last week and after a few hits with a plunger a chux came out the other end. And I am not pointing a finger.
Fill your sink with hot water and some Bi Carb then take out plug and plunge the water through.
Mechanised Swaggies
Go with Sue and Phils way or take the hose inside ,jam a rag around the hose after you place it over the plughole and then get another person to turn the hose on full! hold it for @ 1 minute. If that works charge yourself $110 for a service call and have a drink on yourself !!Cheers John. { Don,t laugh ...I had a call from a tennant in the local c/park last week for the same thing and thats how i fixed it...out came a big gob of fat etc and that was my fee }
hi Gerty,
An easy way to sort fat or more likely particle build up is to block off the drain where it it exits the van. I just brought the screw attachment form bunnings that fitted my pipe size and glued it on and then put the bung in it. Once drain closed off fill sink with hot soapy water and demestos then take out plug and leave in drain overnight. then remove bung. Just a note, in our van the bathroom and shower are all connected so could be anyone that is causing the block, hair is a bad one. It is a disadvantage of being water conscious in a house on mains water enough water goes down to flush most things out
Opinions are a persons way of thinking, you dont have to agree with it but respect it
Thank you all for such helpful and prompt replies. Looks like we'll be at a hardware store looking for a plunger.
There's a couple of 90 degree bends in the drain, I reckon a bit of toothpick or similar might be wedged in a corner, then other little bits catch on it.
Gday
Looking at your photo - looks like a Jayco.  If it is, then don't use draino until you check the pipes under the van.  Get underneath the van where the sink pipe goes thru the floor and you may find that there is a 90 degree elbow if the pipework.   That is where mine used to block.  I used to pull it out of the pipe going up thru the floor and then you can put a hose in (preferably on the other end) to flush out any blockage.
-- Edited by Treecrest14 on Friday 25th of July 2014 08:05:28 AM
Glen
I was told by a plumber that after washing up pour a jug of boiling water down the drain.
Our van sink was slow to empty but now works fine, boiling water works for us..
Agree with Nelly bi carb and vinegar , then every couple of days just pour boiling water down ,keeps ours clear..hope this helps
traveling trio
traveling with me and my two birds
smile and the world smiles with you
If you don't have a plunger try slapping outlet with your hand so it works like a plunger..
Try not to wash fatty utensils in sink ..
We use hot water in bucket with strong dishwashing liquid, also carry automotive degreaser diluted  in spray bottle
to clean BBQ outside..
-- Edited by Aus-Kiwi on Saturday 26th of July 2014 10:55:24 AM
I shoved a hose up mine from the outside, then down through the sink which loosened a blockage. Did not have the water running until it was clear. Otherwise the plunger does the job.
