Post Info TOPIC: SEATBELTS- HELP!
SEATBELTS- HELP!
Hi Im just looking to get a campervan fitted out. Trouble is its a 2seater sprinter. I had hoped to put two seatbelts on the side facing lounge- making it carry 4 legally (professionally done of course). Does anyone have these???
Or  how about installing 2 more seats (like a diner- with seatbelts). Has anyone had any of these done? ANY HELP much appreciated- even if anyone knows legal bits for Victoria.
Cheers Didi
'The greatness of a nation and its moral progress can be judged by the way its animals are treated'  - Gandhi
http://travelsofagrey.blogspot.com.au/
Hi didi;
         Call in and see your local RTA office and ask for there recomindation of a approved engineer that 1/ could possable do the work for you and 2/ sign off on the work as changing from a 2 seater to a 4 seater would require meeting RDA reqirments ( seat belt mouting points etc ).
RTA's not happy until your NOT happy :)
Yes Bas +Eve the rta also aren't happy till they've got all your cash.
Ashley
Thanks valiant. I think the conversion guy has a VASS engineer on board for electrics etc. But I just wondered if ayone had already done this? And what was the outcome? cheers Di
Cheers Didi
Di  here's the information from VicRoads
 http://www.vicroads.vic.gov.au/Home/Registration/PermitsModificationsAndDefects/Modifications/RemoveAddReplaceSeats.htm
I fitted 2 to the side lounge on mine but haven't had them passed as I only fitted them for emergency's, ie picking up people who have broken down or had an accident, I used the center belts from the back seats of some Subaru's I pulled apart a few years ago, they weren't long enough so I cut the webbing off another belt and had them extended professionally by the guy who made my window shade.
I used 50mm X 50mm X 5mm thick steel as a base plate behind where I drilled them in and also used proper high tensile seat belt bolts.
So if they are not to be used normally this may be an option.
I'll get there one day.
Hi  to be legal the seat belt mounting plates need to be<3mm generally Aust wide and Vic specify 1.5-3mm. This is the most critical as in an accident a heavy plate tears the floor pan and a thinner on distorts with it and is a lot stronger.
See this link
 http://www.vicroads.vic.gov.au/NR/rdonlyres/E595766D-49EE-4B20-B834-8328C3F5E9E4/0/VSI15.pdf
Thanks for that though I think if I had a decent accident they would have a 250L fridge followed by about 200kg of tools squashing them into the front seat :(
What ever direction you take, then eventually it will have to be Engineer Inspected and Certified by all states of Australia to be legal.
But, your thoughts are worth a reward.
Cheers and good luck with that conversion.
Kalangadoo with a wheel- barrow & Waterbag
