Post Info TOPIC: aluminium radiators / static electrolysis
True or false?? It has me beat !
A hot aluminium radiator retains a static voltage when hot. Even with ignition off. Test for yourself. Mine did on a Toyota REV 4.
I replaced the radiator,the core just fell out into pieces like " brittle" it's about eight years old. The right Toyota long life coolant
was used all the time, and distilled water, and I flush and replace it regularly every two years.
This is what an auto electrician told me, "static electricity  electrolites (apparently) causes aluminium to deteriorate
faster during the years. A small earth wire screwed to a  cooling fin  discharges the radiator which is rubber mounted
and not earthed. It no longer holds a static charge now after fitting the earth wire. Engine running and off with hot radiator.
I have yet to believe that it makes any difference to the radiator condition over the years, causing it to fall apart.
The problem is usually caused by using the wrong coolant in aluminium radiators, this is not the case.
Any ideas, I am curious, thanks college of knowledge.
Keith
This can be an issue if earths are not connected properly ..
 Agreed ,  Bad earthing is the most likely cause   They tell me  at the workshop that in  new type vehicles the radiator  tanks are plastic  and if not grounded will be subject to wind induced static so over time they corrode .  The radiator  bolts are normally not into the metal body  surrounds but into plastic inserts  so are  insulated from earth, they over came it with an earth wire to the under body metal work.
