Post Info TOPIC: Fiamma Awning
Fiamma Awning
Does anyone know someone in Melbourne / Victoria that services Fiamma awnings please..
Judy
Here are the dealers in VIC:
www.fiamma.com/EN/service/dealers/
COAST TO COAST RV SERVICES VIC
3 Frog Court
3064 Craigieburn , VIC
03 9305 6566
www.coastrv.com.au/
Goldstream RV
12 Embrey Crt
3810 PAKENHAM, VIC
03 5941 5571
www.goldstreamrv.com.au/
Milners Caravans
14 Endeavour St
3820 WARRAGUL, VIC
03 5623 4104
www.milnerscaravans.com.au/
Here are the technical support centres for Australia:
www.fiamma.com/EN/service/technical_support/
Mr. Yuan Ren
Camec Pty Ltd
Unit 1/2 Garner Place Ingleburn NSW 2565
Tel 02 8706 0888 - Fax 02 8706 0899
enqnsw at camec dot com dot au
Mr. Martin Newberry
Mr. Gerald Tripp
Coast to Coast RV Services
32 Station Street 2117 Dundas NSW
Tel 02 96471164 Fax 02 97488424
Thank you I will ring them...
Judy
What is wrong with you awning Barina. :)
oldbobsbus@gmail.com
 Last time I used it, as I wound it up to the top it did not lock into the cover. Was pretty close, so I wound it down a bit and it just completely unwound and I thought S*** and hoped it would wind up which it did thank goodness. Now I am a bit unsure wether it should be used without someone having a look at it. I did unwind a metre or aso at home and seemed fine locked back in at the top ok.
Judy
sounds like the winding mechanism has tossed in the towel..cry
I have had that happen twice (on different awnings) and it isn't a cheap part to replace, the only good thing is that it is an easy job to do..
If you can give me the model of your awning  (the numbers on theoutside of it including the small digits) like F45is. I will get you a price of a replacement winder mechanism..
 It is a Fiamma F45 plus....thanks
Judy
