Post Info TOPIC: Using a clevis slip hook on safety chains - legal?
As per the heading, I've noticed a few people using clevis hooks to make it easier to attach safety chains to their towbar. They maintain that the clevis hook is legal as on the packaging it says suitable for caravans and the load rating is more than adequate, however I've always seen "Dee" shackles used for this purpose and I thought that was all you can use legally.  Appearance wise they look pretty daggy hanging down but apparently can save you getting on your knees to attach chains.
So,  does anyone know for sure?
http://www.uscargocontrol.com/Tie-Downs-Hardware/Wire-Grab-S-Hooks/1-2-Clevis-Slip-Hook-Grade-70_2
I doubt it would be legat.
The laws state that attatching methods must be as strong or stronger than the chain which itself must be able to take the weight of the van both dropping onto the chains & towing that van.
Although these hooks may be rated high enough they are rated as SLING hooks which means they are for lifting, not taking the shock load of a van falling off the towbar.
My thoughts anyway.
Neil & Lynne
Pinjarra
Western Australia
Nahhhhhh not for me I have had a trailer come off and I know how much load the chains and shackles take before it situation can be rectified..
Even with the lock clip I would worry that they can come unhooked ...Also you would need an extra large hole to hang them from..
Would you hang them clip up or clip down.?????
oldbobsbus@gmail.com
We use them on our trailers, attached to the chains, they just clip onto the shackles on the tow bar. Makes hooking up and unhooking so much faster and easier. Never had one come undone ever and use them on chained dog and pig trailers for many years.
D clamps anyday for me, my rigs worth the effort of bending down ,we don,t detach every day any way .
I spoke to police in NSW and was told that you must D shackles and preferred Bow line D shackles rated at least double of the weight of the van. Anything else is not legal. I was considering the clevis hooks for ease of attaching, etc so thought I would find out what the law said.
Also in relation to this area the chains must also be rated to take the snap weight if the tow hitch should fail and should be of a length that will not allow the A frame to reach the ground.
so hope that helps
briche
Thanks for the replies......think I might persist with the D shackles till I'm sure it is legal to use clevis hooks.
briche - I know that's the intent of the law but from what I've seen it is impossible to stop the A frame hitting the ground.
While some States highly recommend the use of suitable rated shackles there is no legislation requiring them to be used.
You can use anything you like including fencing wire, but must be able to show that each item of what ever you're using is capable of supporting at least 1.5 times the ATM of the trailer.
For me that means I used Rated Shackles and not unbranded (Unrated) shackles from various outlets including HR.
Cheers, Ozjohn.
I'm with Ozjohn on this one I use rated shackles everytime  from 6x4 trailers to my Flat Tow Suzuki. Too much at stake both in financial terms and Liabilty towards other road users.
Not keen on getting on my knees but a garden knee protector pad to use when attaching the shackles helps.
The clevis pins are fine for tension but not for shock. I know they are rated to a large tonnage for tension but  shock is a totally different thing.
Here's the QLD safe towing guide based on VSB1, and chain breaking strength must equal the trailer ATM (refer VSB1)
http://www.tmr.qld.gov.au/Safety/Vehicle-standards-and-modifications/Loads-and-towing/Safe-towing.aspx
Here's the relevant info.
The length of the safety chain/s must prevent the trailers drawbar hitting the ground if the
trailer is detached from the towing vehicle. The safety chains must be properly connected to
the tow bar with attachments capable of withstanding the specified breaking load of each
chain. Do not use padlocks.
Plus
Safety chain connections (shackles, pins or bolts)
A suitable shackle is where:
the shackle is rated and complies with Australian Standard AS 2741-2002 Shackles
    • or other equivalent recognised standard; and
    • the break load limit of the shackle is rated at least 1.5 times greater than the ATM of
      the trailer.
 PS; I'VE NEVER SEEN A 4.5 TONNE RATED CLEVIS HOOK
-- Edited by Baz421 on Tuesday 18th of March 2014 12:49:10 PM
-- Edited by Baz421 on Tuesday 18th of March 2014 12:51:31 PM
KFT
Hey Baz
have a look at these ones
I will have another go at the link
 frank
-- Edited by KFT on Tuesday 18th of March 2014 01:40:33 PM
Avagreatday.
KFT wrote:
Hey Baz
 frank
 OK you got me there,,, but you will need special towbar OR a deep throat, rated D shackle to attach to vehicle would you not?
Don't get me wrong I'm not trying to be negative, just practical.
I didn't think you'd be using a crane lifting hook/chain tie down that size, in my wildest dreams (and I do have em) but you got me here,, lol.
If you buy these hooks they may not fit your existing chain on your van and you can't weld the chain you use with this hook ie it's high tensile garde 70 chain, so again you would need a rated D shackle to attach the high tensile chain to the A frame of your van, ie to the original chain link welded to the A frame.
Have you created a "monster"????
Cheers Baz
Our hooks are on the chains, they hook over shackles on the towbar, just slip them in, takes a second to do and no getting down trying to undo the shackle. They have a break away strength of 15tonnes, so don't think they will bend or break.
Baz421 wrote:
SNIP
SNIP
Thanks for that Baz, but it ain't possible on most setups as the safety chain connection is placed in such a position that the chains must be long enough to allow the vehicle to turn.  I've never had one yet that doesn't hit the ground. I should add that I'm talking about cars/SUV's, not 4WD vehicles that are much higher than cars.
But I welcome advice on how to overcome this problem.
hako wrote:
Baz421 wrote:
SNIP
SNIP
 Yeh I agree our aframe will hit the ground if we have a ball/tongue failure. We have a Reece WDH made in USA and ball is set back about 300mm from chain anchorage points.
$T2eC16Z,!)8E9s4l8BQ2BRjKTC0hJ!~~60_35.JPG     Watched someone last week  attaching the chains on a  Camper trailer  with two of these.  No way would that take a shock load  of that camper coming off the ball.
Mike & Ellie
 Agree 100%. They are not load rated generally however some marine stainless steel ones are, but as I stated earlier I haven't ever seen one rated at 4.5 tonnes which I would need for my van.
KFT wrote:
Hey Baz
 frank
 Firstly, these are manufactured in China and marketed in the US. It is highly unlikely that the manufacturer or marketer is even aware of Australian Standards let alone what is required to comply with them.
Secondly, I cannot see any indication of what standard these things do conform to and my experience with Chinese manufactured products doesn't give me a lot of confidence that they conform to any standard.
If you want to go down this path then at least contact an Australian supplier of these types of products that conform to Australian Standards and seek their advice about the legality of such products in the way you wish to use them.
See you on the road
Baz421 wrote:
KFT wrote:
Hey Baz
I will have another go at the linkhttp://www.uscargocontrol.com/Tie-Downs-Hardware/Wire-Grab-S-Hooks/1-2-Clevis-Slip-Hook-Grade-70_2
frank
If you buy these hooks they may not fit your existing chain on your van and you can't weld the chain you use with this hook ie it's high tensile garde 70 chain, so again you would need a rated D shackle to attach the high tensile chain to the A frame of your van, ie to the original chain link welded to the A frame.Have you created a "monster"????Cheers Baz
 It's illegal to attach the chain to the A-frame of a trailer using shackles.
Ozjohn
Ref: ADR62/01
14.3.1.                          Safety chains must be permanently attached to the trailer.
14.3.1.1.                    Shackles are not permitted.
ozjohn wrote:
Baz421 wrote:
KFT wrote:
Hey Baz
frank
Ozjohn
Ref: ADR62/01
 Yep that's why I said he creating a monster,,, you know a cluster F***.
It wpreall y is a load of (looking for the word) is it not, the caravan come with a chain or chains. Cheers.
 What ?
Mike & Ellie
Baz421
If you wish to tow say 3500Kg you don't need 3.5T Rated Shackles.
2.5T or 2T etc will suffice.
The WWL (Working Load Limit) of Rated Shackle is 6 times the Rate shown on the shackle in the case of an 'S' or '6' rating. (will be stamped or embossed on the shackle body).
In the case of an 'M' or '4' rate it is 4 times the shackle rate shown.
From memory and without looking at by data sheets the breaking load limit is around 19 time the rates shown on a 'S' or '6' rated shackle.
Travel safe us only Rated Shackles not unbranded ones or ones just showing the towbar manufacturers name.
Cheers, Ozjohn.
ozjohn wrote:
Baz421
Cheers, Ozjohn.
 John on 18/3/14 I posted this quote from QLD transport.
      the trailer.
Baz421 wrote:
ozjohn wrote:
Baz421
Cheers, Ozjohn.
the trailer.
 Baz.
True: Whatever is used must be capable of supporting 1.5 time the ATM of the trailer.
Shackles are rated at WLL not Breaking Load Limit, so a 2T 'S' or '6' rated shackle has a WLL of 12T.
But personally I prefer to keep well under the WLL.
Cheers, Ozjohn.
OK, I've read all the above but need just a bit more clarification.
Yes I use rated shackles, the gal ones with the yellow pin. Is it fair to assume that the largest shackle (pin) that will fit through the hole in the towbar will be good enough to do the job? (If I'd been making towbars I think I would've made the holes larger.)
-- Edited by KevinC on Friday 21st of March 2014 12:00:37 PM
This is copied from the National Caravan and Recreational Vehicle Site.
 The chains attach the A frame or drawbar of the trailer to the main towbar framework on the vehicle. The attachment must be made with D shackles of equivalent strength to the chains. It is vital that the chains are attached to the main towbar framework and not to a detachable ball mount or tongue. Safety chains must be stamped with the chains capacity, the manufacturers identification and the digits 4177.
This is the main page.
http://www.towingguide.com.au/content/couplings.html
 Unfortunately a towing guide issued by a private organisation DOES NOT replace/supecede the QLD Transport bulletin I posted as this takes precedence (in QLD at least) and other states will have their own versions presumably.
On my trailers from boat to car trailers I have two chains and two u section welded to draw bar so I only need a pin through chain link. This way the D shackle can't be lost !! I've lost way too many over the years on boat ramps.. Trying to explain why chain is around ball gives no one any satisfaction !!
