Post Info TOPIC: truma hot water system
anyone having trouble with coromal hot water system three elements replaced in under 2 years wal
w g howard
KFT
Do truma HWS have a sacrificial anode?
Have you changed it when required?
Most electric elements that are submersed in water fail due to corrosion of the sheath enclosing the heating element. The corrosion can be minimised by corrosion protection like an anode.
so it is important to check it each 6 months and replace when it is nearly exhausted.
frank
Avagreatday.
frank
 Truma units are normally stainless Steel tanks, so there will be no anode.
it works on gas all right but it has never worked   on 240 from  new dont know if just bit the bullet and replace it
w g howard
 If it has never worked on 240v - why have you replaced 3 elements?
coromal has replaced the element twice under warranty saying thats the problem. vans going in next week dont know if they will fix it under warranty again.he has changed 6 vans with the jayco heaters but its about 1500 to do it
w g howard
So, does it work for even a short time on 240v after they fit a new element?
We have 14 litre Trauma gas/240 system in our 2007 Jayco conquest, no problems with unit on either gas or 240, no anode in these, would suggest either thermostate or 240 switch, fuse.
Bob
Bob
Sit, watch and wait.
Master (of Mischief)
 walwal, you need to phone ACCC on 1300 302 502 explain what has happened and they will advise you what action to take, do it NOW.
http://www.accc.gov.au/consumers
http://www.accc.gov.au/consumers/consumer-rights-guarantees
We have a Truma 14 L 240V gas HWS in our motor home, has never given us any problems, operates in either mode first time every time.
Why not get an independent assessment from another experienced installer, I suspect the original installation is the problem, either that or a faulty componant in the unit.
No they don't have a sacrificial anode.
Santa.
Our Truma HWS is just over two years old. Probably been used 6 times. Recently  started playing games and then yesterday no hot water at all. Instruction book did not shed any light.  as we are away, not sure what the next move is.
DMBM
