Post Info TOPIC: Towing Vehicle Options/Opinions
Howdy,
Im looking at buying a new vehicle to tow my poptop van (17ft, 960kg empty, mechanical brakes) and was hoping on any feedback , pros & cons on the following vehicle based on towing, comfort and fuel economy.
Looking at 4x4 and diesel engine/auto
Mazda BT50
Ford Ranger
Nissan Navara
Toyota Hilux
Any advice or opinions would be greatly appreciated.
Cheers, Brad
Got 3 ltr Ranger get around 13.5 ltr the 100 km
Cheers John
Don't go Hilux, not like they used to be, even the mine companies are starting to look elsewhere
Never get so busy making a living
that you forget to make a life
The ranger and BT50 equiv are more popular than Jesus from what I can see on the road.
Check out the VW Amrock reports about it's tow capabilities and fuel consumption in the Caravan and Caravan magazines. People will tell you no way spares are hard to find. Most stuff has to be freighted in from the main warehouses for all makes so that doesn't wash and the reliability factor is a major plus.
Guy in the park next to me has the base model and says he wishes they had been around years ago.
I picked up my BT50 in January last year and left home towing a 21' Paramount Classic, fully loaded in June. Done in excess of 27,000kms to date and it hasn't missed a beat.
I upgraded the suspension in Darwin, otherwise it's stock standard. It is a Freestyle cab/chassis with a steel tray. I'm also carrying a Hobie Mirage Outback kayak on top. Did the Gibb River Road (without the van) and it performed faultlessly.
Best bit is, it was about $7000 cheaper than the Ranger.
You could do worse.
The Phantom
-- Edited by The Phantom on Wednesday 29th of January 2014 08:45:18 PM
id buy a imarok if i had my time again but my colorado does a good job
dibs
gdyble
I am not having a go at bt50s, but the next door neighbor blew a motor is his because of worn injectors and bad fuel.Common rail diesels inject at very high pressures, and their injectors wear out quicker. Has anybody else had any problems. Bill
Landcruiser 200 series. If you decide to go to a bigger van, you've got the tug.
I would say dirty or contaminated fuel ?? Someone part filled with E10 ??
Its looking like the Ranger XLS Dual Cab...Thanks for the advice y'all
Cheers, Brad
hi mate
what was your fuel rate with your bt50 as we have one and was wondering what you get.
    regards norm
