Post Info TOPIC: Caravan fridge
Caravan fridge
Over the last many months we have had trouble with our Electrolux fridge not staying cool enough in the hot weather. Alas as we were free camping at Fort O Hare in Dartmoor and having our happy hour which lasted for hours we realised that our climate class was SN which stood for Sub normal. We should have a T =tropical fridge. There are four sorts, SN, N T ST.
At last our problem is solved so off to buy a new fridge for the right conditions.
Most new vans have T fridges so for the unaware watch that.
No more will we have to be looking at the digital thermometer.
You learn something every day, which is wonderful
"No matter what happens travel gives you a story to tell"
 Before you jump in the deep end you may be interested in reading these posts;
Enter the headings into the search window;
If you want the results then let me know, you will realise why I never made them public if you have a read.
I supplied them to about 25 members via PM & email.
JC
who has put 12 volt fans on van fridges  ( 1 2 3 ) (Preview)     Techies' Corner     blaze     62     2637
05:58 PM Dec 18, 2012
by Webmaster
     SOME TEST RESULTS ARE IN ON THE FRIDGE INSULATION.  ( ) (Preview)     Techies' Corner     justcruisin01     15     766
05:47 PM Jan 4, 2013
by justcruisin01
JC.
KFT
 yours might work ok a bit further south(pole area)
seriously though it may make a good little beer fridge in your shed where it can get plenty of air.
frank
Avagreatday.
I'd try what JC suggests first before going to the trouble of replacing it. We insulated ours and added the fans and it really does make it icy cold.
 Well done Hako; Another member has just done his as well.
JC.
we put a fan in ours and over xmas performed well will now be putting insulation in to improve it further
Neil
you are never too old to set another goal or to dream another dream
Neil
 The insulation is the main part, the fans do help.
JC
JC.
I would also try JC first . Worked for us .Pie warmer to 2 degree or less fridge .Saved us a bundle
Chris.
 Good one Chris, just have to putup with the cold pies; Bugger.smilesmilesmile
JC
JC.
What do you mean by...We put a fan in the fridge....
Please explain.
Frank
http://www.adclickxpress.com/?r=Noj4ZdvsXR&p=bo
Some people actually fit a fan inside the fridge to blow over the cooling fins and circulate the cool air.....this is in addition to the external fan(s).
