Post Info TOPIC: algae in water tanks ?? smelly water.
They tell me if you use chlorinated town water in tanks algae does not occur.
Maybe because of the hot weather I notice the water is smelly, but the filters are clean and
just replaced. Tanks drained and refilled with recommended water treatment, but still smelly.
Always sealed so I don't think it's frogs or bugs getting in. All the pipes are clear as well.
I may need a heavier cleaning solution. Thanks advice appreciated.
Keith
Put a small box of Bi-carb Soda in your water tank half to 3/4 full take the van for a spin and you should be right again Keith
Cheers John
and after clean the tank out of course ,refill a few times with clean water
By the time you get the town water to your tap, there in not much chlorine left and what is growing in the tank could just keep growing.
Give the tank a dose of household bleach (non perfumed, clear) each week or 2.
Use about 10-20 ml per 100 litres of water. More would be better for a while.
If your filter is a decent one (1um active carbon) and is fitted in the pipe after the van pump and just before the kitchen tap, it will remove any chlorine left in the water, but the quantities I mentioned probably won't be noticed.
Thanks John and Peter. Makes sense.
That coffee was tasting bl....aweful.
Keith
