Post Info TOPIC: Difficult 3 pin plugs - insertion and removal.
Maybe I'm the only one, but the newer types of wall electrical outlets and the newer style of 3 pin plugs seem to be harder to insert and remove. They feel rough and seem to grab on removal....just a cheap feeling about it. Maybe it's the cheap and nasty electrical items we can only buy these days but it got so bad with me that one time trying to remove the plug from the outlet resulted in me pulling the outlet partially off the wall.
The solution is pretty simple - it may not be politically correct or 'by the book' but it works. Get a can of pressure pack lanolin and either give a quick squirt in each of the 3 holes OR spray the prongs on the plug and insert.  Wipe off any excess and just a split second spray will do. The plug then will insert and remove like a finger in you know what. The lanolin will leave a lubricating film that will last for some time.
Good Luck
Yes, I have been told that the cheaper gpo is more difficult to use.
I have noticed this also
Some of our new appliances have 'grab holes' in the plugs which make it so much easier to insert and remove.
NeilnRuth
HI
Actually lanolin is not the best the redidue can collect dust & lead to high contact ELECTRICAL resistance
CRC 2-26
Is specically designed to clean & lubricate electrical contacts !
PeterQ
KFT
X2 for the CRC 2-26
excellent product for lubricating electrical gear
frank
Avagreatday.
Good advice re CRC Denis.
But the plug shouldn't be tight,,, I've previously cleaned some rough edges off the plug tangs,,, small file or glasspaper can round off sharp edges and they often fit better.
Cheers baz
The plug-holes in our caravan are horribly tight, the same appliances plug in and out easily in the house. Not sure why, maybe the power-points are Jayco specials. Will try the CRC, Thanks.
Cheers,  Gerty. ... at home
Or WD40...
confuselike a finger in what?confuse
Master (of Mischief)
 I have to resist telling you, even I know that and I'm only a wombatbiggrinbiggrin
