Post Info TOPIC: How to eliminate sink odour?
There is an unpleasant odour emanating from the caravan galley sink. I don't know what I could safely use to clean the grey water piping to eliminate this smell. Does anyone have a recommendation for what I could use?
KFT
try some nappy soaker dissolved in hot water.
block the outlet and fill the pipes but don't forget to put the plug in the shower(if installed) or you might flood the shower.
leave it for a half hour then drain it.
worked for us, we do it about every year or so now.
frank
Avagreatday.
I use carb soda with white vinegar poured over it. I use this at home so it may work - bubbles up a bit but does the job here.
Where there is a will there is a way!!
Thank you Frank and Nelly for your suggestions. I'll give one or both of your methods a go. R.
The Happy Helper
We use enzymes - available at the supermarket - in liquid or pellet form - we use the pellets - a large teaspoon full every month seems to keep things pretty sweet!
jules
(Ben, aged 10)
Bicarb and white vinegar..Or PLUG ??
Problem fixed. The smell is gone. Thank you to everyone who offered recommendations.
KFT
so what did you do that fixed it?
just so others will know
frank
Avagreatday.
