Post Info TOPIC: 240/12 Volt Fridges
240/12 Volt Fridges
PRADO 1 wrote:
Hi, My name is Brian and I am a newby at this forum and I was wondering does any one know about weather proof 240 sockets to fit on back of car for a Waeco fridge that is permanently in vehicle so when in caravan park do not have to keep opening back of Prado to plug it into 240 volts.confuse
 HI Brian
Fitting such an inlet & then a socket inside , requires a licensed electrical contractor to do the work
IT is considered FIXEd wiring
Certain safety precautions have to be taken,[including earthing] But I would suggest you have a 10Amp  CARAVAN inlet fitted ,rather than the usual 15A caravan inlet
SPECIFY CARAVAN inlet, AS they meet the requirements of the  STANDARDSsmile
This will allow te use of an APPROVED 10A extension lead ANYWHERE [CP , hme! freinds ,Show ground etc)
IT will require a RCD /10AMCB to be also fitted & wired in!!
PeterQ
PeterQ
-- Edited by oldtrack123 on Monday 11th of November 2013 09:37:32 PM
Welcome Brian.  Can't help with your Question, but please where did you get that Crab ?
On a fishing charter in Darwin a few months ago. Six crabs but no Barramundi but they tasted good. Have to wait and hope someone can help me on my question.
Where and how are you intending to mount this inlet?
You could feasibly use a normal caravan type inlet plug, but it would need to be well enclosed and moisture proofed at the back and protected from impact damage, you should also employ an RCD for personal protection.
The work would need to be done by a qualified tradesman to ensure legality.
An alternative to the caravan inlet, would be the Clipsal surface mount CL156A1310 or the flush mount CL156A1310LE.
Thank you very much for that information guys, I will start checking out some electricians on prices and plugs now, Thanks again.
