Post Info TOPIC: Still stuck in PA
Still stuck in PA
The adaptor leads arrived this morning, and it appears the problem is a faulty sensor on the injector pump.
 A replacement is on its way from Brunswicks in WA. In fact they are sending two, in case one of these is faulty also.
 Expect it to arrive Friday, so have paid up the caravan park till then.
BB
You could always put all that spare time brushing up on the scones, pavs and camp oven casseroles/stews skills. But then again, how can you improve on, perfection.
Hope you get away real soon Mr and Mrs Kiwi.
The Happy Helper
Hope it all gets sorted this time guys - you are missing some good road time.
jules
(Ben, aged 10)
I know your wallet has had it's butt kicked over this but, if you could swing it grab a hire vehicle and explore the Flinders Ranges, or parts anyway.
Which way are you heading when you get mobile?  If toward Adelaide may I suggest you turn left off the highway just south of PA toward Wilmington then south threogh Clare Valley to Adelaide.  A much nicer drive than Highway 1 south.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
The Happy Helper
Definitely Dleta18 - a much nicer trip - and beautiful wines as well!!!!! Take note Brandt!!!!!
jules
(Ben, aged 10)
Delta 18 and Jules, plan on heading to Renmark via Clare. which is the best way from Clare.
Would still like to drop in and see the MOB at Greens, if time allows.
BB
Possibly down the coast to Crystal Brook and then towards Gulnare (turn right just before Gulnare) and then straight to Clare.
If your main destination is Renmark and you are not fussy about Clare etc then continue through Gulnare to Burra and then on to Morgan on the Murray River and then to Renmark.
Good camping at Burra and also at Moorook when you get to the Murry and if you head Clare way then there is a good spot just after the bridge on the left at Yakka.
Brian
Sorry to read that guys and hopefully that's the end of it. I would agree, Clare is the better way to go.
i guess you have been at PA for so long they should give you a farewell party. Sorry.
take care and hope all goes well this time.
Brian and Cheryl.
All the best Kiwi-as. Hope the new part does the trick. Take care.
NeilnRuth
I would head to Wilmington then Clare, Burra the Murray river either via the ferry (free) or across the bridge a bit further up. Melrose is a nifty camp area and if the wallet stretches nice wineries around Clare. Less traffic that way as well
Pete
I have heard on dubious grapevine the Dept of Immigration might issue you two with a citizenship of Pt Augusta. You will naturally need a passport to exit the town.. biggrinbiggrinbiggrin
Hope it all goes well with the repairs.
Pete
I agree the Clare Valley is a nice area to visit, sadly it seems to have been in decline over the past 10 years or so, restaurants and other businesses have closed and not been replaced.
Was a time there was a financial benefit to visiting wineries, cellar door prices were always very reasonable and the odd bargain was to be had, nowadays, sadly cellar door prices are sky high, the same wines can be bought much cheaper at Woolworths, makes you wonder whether WW are bringing any pressure to bear.
Santa.
