Post Info TOPIC: Tie downs
Tie downs
An ideal solution for holding down shade walls etc...when you can,t quite reach the ground is to use large plastic ties ,very strong and adjustable .OK if u are staying for extended period. Ties are available that undo, no need to cut them.
pa bradley
The Happy Helper
Do you mean cable ties? We have some really long ones, but they have to be cut off.
jules
(Ben, aged 10)
Hi, if you have thicker ones(large) you can release them with a small flat screwdriver. Just lift the tab in the centre.
pa bradley
