Post Info TOPIC: How To Shell Garlic Cloves
Duh
Makes it look easy.....good upper body exercise too, lol ! smile
http://www.wimp.com/bestgarlic
cryevery time one of these hints is posted i tell my wife and she says "if im not doing it properly you can do it in future"
am i doing something wrong in educating her ?????confuseconfuse
brian
Duh
Hmmmm......sometimes silence is golden....wink biggrin
i get plenty of that
brian
The Happy Helper
Rubbing between the hands in rubber gloves works as well - and you can buy a garlic peeler, which is essentially the same thing as the rubber gloves!
jules
(Ben, aged 10)
If it is Australian garlic no need to peel, just bang a clove with the back of a knife or even the palm of your hand and Bingo it's peeled. ...Also Australian garlic is a lot stronger than that white skinned imported fumigated with chemical pretend garlic...
Time To Sleep Later In Life.
I wonder if that would work with 5 kilos of spuds.
Gary
Another garlic peeling trick to add to the repertoire - have to see how well it works in plastic bowlsbiggrinbiggrinbiggrin
See you on the road
