Post Info TOPIC: What car is a Jayco wheel similar to?
We have a '11 Jayco 13' StarCraft, do the wheels stud pattern match a Holden, Ford or Toyota? Or anything?
Steve & Liz
I think you will find they are the ford stud pattern, nearly all Jayco,s are ford I think , I stand to be corrected.
Lance C
http://www.google.com.au/search?q=%22stud+pattern%22+wheel
STUD PATTERNS - VEHICLE WHEEL FITMENT GUIDE:
http://www.pexcom.com.au/z32cms/e107_plugins/content/content.php?content.561
"PCD stands for (pitch circle diameter), this is the diameter of a circle drawn through the center of your wheel's bolt holes. PCD is measured in millimetres and also indicates the number of studs or bolts the wheel will have. The most common fitment has 4 studs with a PCD of 100mm, hence the fitment 4x100."
http://wheelstudpattern.com/
-- Edited by dorian on Saturday 28th of September 2013 05:54:45 AM
just drive past any tyre place they will tell you
cheers John
take the spare wheel with you so you dont have to bring the caravan
thanks guys
Steve & Liz
