SmartBar Mackay Festival of Arts Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Stuck Wineguard aerial
Simple question and hoping for a "simple" answer ?  Have a roof-mounted internal wind-up Wineguard aerial which seems to be stuck down somehow   confuse
Do not want to force it as it'll probably break something angered.gif.  Have yet to try someone up top while I try to wind it up from inside cry
Any suggestions thankfully received smile
I had mine get stuck in the half way position. Silicone spray works a treat - wind, when they are left up overnight etc can slightly dislodge the spokes and that can also be a cause. The advice given to me by the repairer was always wind the antenna down when not in use and every 6 months or so spray with silicone.
-- Edited by Lorries on Tuesday 10th of September 2013 09:30:31 AM
A small step for mankind is a giant leap for me.
-- Edited by Lorries on Tuesday 10th of September 2013 04:57:25 PM
Hi Greg
I found this
http://www.winegard.com/kbase/kb_tip_results.php?tip_num=00000000048
http://dutchmen.com/image/data/documents/parts/2451808.pdf
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/24691105.cfm
this will keep you going for a while and fix the problem
Good Luck  John
I have never had mine actually get stuck but it has become hard to wind so from the top I have sprayed into the cable some silicone lubricant and it solved the problem
Just read on my internal winder mechanism "LUBRICATE GEARS TWICE A YEAR". Hmmmmmm.
Thanks all......much appreciated.  Been under Stormcover for 6 months so the silicone lubricant seems to be the way (retrospectively anyway) to go.
TAJ
BIG GREGG make sure the little pointer arrow is in the right position inside the van
                       suenray
My 4x4be aerial got stuck once during a trip on Gibb River Rd , must have got some dust in it,all I had was a can of silicne lubricant so hoped for the best and bingo worked no probs and never had any more stuck aerial .
Time To Sleep Later In Life.
