Post Info TOPIC: Advice on TV arms or turntables please
Duh
I am looking putting a TV arm in my campervan, I have a few options, I could put a turntable type on a high bench, but it would take up bench space, the bench has an overhang where I could possibly put a below bench retractable arm (with TV taken off) or one that bolts onto the side of the the van (folding arm type).   Looking for suggestions and advice please.
Also, do TV's on these holders need to be put away if they are ok folding back where the bracket is ?
Here are a couple of pics of the bench and overhang, some minor changes have been made to the van since these were taken etc;DSC00160.JPGDSC00167.JPG
G'day Vic
where do you keep your TV normally Vic
I was thinking maybe a folding down shelf what you can open on the top part on one of the back doors to put the tv on , depending where you are sitting of course
we put ours under one of the bed pillow on the bed when we travel, for me an arm like that shakes a fair bit when traveling
I hope this will help you a bit
Cheers John
Duh
Thanks John, I don't have a TV at the moment, but was thinking about getting one.  I do have an outside removable antenna though but it does not have an entry point an suspect the previous owner was closing the drivers door rubber over the antenna lead, can't see any other way he could have got it into the van.
That is a good tip, I didn't think of that.   The back door tops inside do not have a lining attached (on the high roof models) I thought they were missing until I looked in a yard with new ones and they are the same, although the lower door ones do have a lining....strange.
I don't want a huge TV, probably a 12V/240V with DVD, LCD, or even just a 240V for CP's as I am not a great TV watcher when away and prefer to read a book.....
Duh
Thanks for the info Richard, the Velcro sounds like a good idea, taking the TV off during travel and leaving the TV on the bed under a pillow or something might give less vibration to the TV than if left on the arm, although you'd have to be careful not to sit or lay on it LOL ! smile
Kogan have a good reputation as far as I am aware among the RV population for price and reliability, but I can't speak from experience.
Keep us informed please when you eventually get yours fitted etc,
Thanks
Vic  PS:  I did see a 240V 19inch DVD model in JB Hi Fi for $99 (their own brand) awhile back but haven't looked much further yet.
-- Edited by Duh on Wednesday 31st of July 2013 10:42:21 PM
UPO
Hi Vic - doing thjs exercise at the moment in a full size van so we can move the TV to a more practical position.
We are buying a 24 inch 12V, TV with DVD through Kogan.com.au - at the moment ( like today ) they have a same spec 19" on special at about $110 - for us a 24 will fit flat against the side wall in a gap beside the fridge and use a longer tripe segment "arm" to come out then 90 deg rotation for viewing.
I am looking at a pair of heavy duty velcro fastened strap to lock the TV into the closed position - the velcoe has vast holding power in shear so looking to have the contact patch in this orientation- still a work in progress - TV weight about 3Kg.
I found an online seller - Cable Chick - http://www.cablechick.com.au/ - and luckily the warehouse is in Capalaba Qld not too far from home & I called in to have a look at one I thought would work to measure it - helpful staff and seem to have a vast collection of odds & ends -
Have no connection with either supplier, just a customer.
Hope this helps Vic
UPO - Richard
Vic, I mounted an arm in our van, bought from Goodguys, double arm but over time (short) the bolts on the arm ( not the mount section) loosen and also the screw at the TV end. Tried numerous fixes over three months to no avail so currently put up with tightening them as required. During transit I use a square piece of foam and fit it under the TV which has worked faultlessly over some pretty average made roads. Would I go this way again.....probably not and if I did I would be doing a lot more research and looking for a money back guarantee if it didn't do the job.
Cheers Jeff
Duh
Would locktite be any good on the bolts and screws Jeff?
I am thinking now I might just sit mine on the bench on it's stand and store it when travelling.
Was yours 12/240V or just 240V?  DVD?
Correction to my previous post (now amended) the one I saw was at JB Hi Fi, not Douglas Hi Fi, have now corrected the post info.
Thanks for the feedback.
Tried locktite Vic, even spring washers etc to no availfurious
Samsung 240v no DVD.
Cheers Jeff
Duh
Cripes Jeff,
If they don't work that's a shame.   Thanks for the info on the TV.
 You want to try nylock nuts.  Take one of the bolts to the hardware store and get a nylock nut to suit
Cheers, Marianna
-- Edited by The dog lady on Tuesday 13th of August 2013 03:48:09 PM
Cheers, Marianna
The more I learn about people, the more I like my dogs (Mark Twain)
Duh
Thanks from me too Marianna, have used them before and they are great. smile
