Post Info TOPIC: LED lights in roof
LED lights in roof
Are you having trouble with LED roof lights playing up with the television,this may answer your problem,only sometimes when the tele is on channel 7 ,when I turn the roof light on it takes away channel7 if I turn it off on comes channel 7 I have two separate lights wich are LED lights turn them on no effect,the light that is affecting the tele has two LED the same,I have been told if I change one of the LEDto a different brand LED the problem will be solved this may be of interest to someone with the same problem.
Lance C
-- Edited by Olley46 on Saturday 27th of July 2013 01:42:53 PM
Hi olley46 have noticed the same problem myself, just turn of the problem light that's the easiest way .cheers shayne
