Post Info TOPIC: Plug Connections (Tug to Trailer)
You'd be surprised how much dust and 5h1t gets into the plug connectors.
A good spray with an electrical connection cleaner does wonders for ensuring a good connection.
CRC spray or WD40 also works a treat and keeps the pins nice and clean ready for the next hook-up.
Mark
Mark & Linda
A man who asks a question is a fool for five minutes, but ask no questions and your a fool for life!!
wrap them up in plastic that safes some problems ???
Never had a problem in 18000 kms round trip!
7 pin round.
Never sprayed, cleaned or found any dirt or gunk in connectors.
Is your connection loose fitting?
Good on ya Leevin hope it stays that way.
ME?
Nope........
Just gets a bit gunked up from time to time with red dust.
The post wasn't so much seeking help or advice, just passing on a little tip and reminding folk to carry out a little check every now and then, that's all!!
Mark & Linda
Good advice Mark.
Another tip is to check all trailer lights simultaneously. This can show up faults that aren't as obvious when checking individually, especially faulty earth wiring, a common cause of problems with trailer wiring.
-- Edited by jimricho on Monday 15th of July 2013 10:22:53 AM
Merda tauris scientia vincit
jimricho wrote:
Good advice Mark.
 Absolutely right, the wife reckons when I do a light check it's like "Las Vegas" strip at the back of the caravan!!  I do it to confuse her really, but she's too smart and all I ever get back is a "Roger Beep" on the two way!!
Mark & Linda
