SmartBar Mackay Festival of Arts Floriade Darwin International Film Festival
Post Info TOPIC: Re D Shackles again
Re D Shackles again
Australian standards quote ,a D Shackle must be rated at 2.5 times the ATM of the trailer,my ATM is 2.160 does this mean my D Shackles have to be 5.400 I have two chains ,is this 5.400 rated on two chains or one.do I need two D Shackles rated at 5.400 each or two at 2.700 each.
Lance C
-- Edited by Olley46 on Friday 17th of May 2013 10:52:37 AM
G'day
Well I would go for the strongest, better to be safe with over kill.
Kev
" Soona be a hasbeen than a never was atall"
All States and Territories require the use of safety chains. Safety chains must be strong enough to hold the trailer should the trailer coupling accidentally disconnect, and comply with the appropriate Australian Standard. Trailers up to 2500 kg ATM are required to have one safety chain while trailers from 2,500kg to 3,500kg must be fitted with two safety chains. The D shackle used to connect the safety chain to the vehicles tow bar must have a load rating equivalent to that of the safety chain.
This is taken from RACQ website on there section on towing
Be aware that the breaking load of a rated D shackle is 5 times its nominal rating.
I can I ask a really dumb question hmm
If my van has a ball weight  265kg surely this is about weight that will "fall" onto the chains. Having fallen to the chains then the BrakeSafe would (should) kick in and begin to brake the van. As soon as the BrakeSafe kicks in the full load of the van, on the chains/shackles would begin to dissipate ... hmm cry
Are we all certain that the full 2,600kg of my van would be the weight that would 'fall' onto the chains therefore the shackles?
"Be aware that the breaking load of a rated D shackle is 5 times its nominal rating.'
If a shackle is rated at 3.5tonne does this mean the breaking load of that shackle is 17.5tonnes (3.5 X 5?)? Would that therefore mean a shackle rated at 700kg would be sufficient for a 3.5tonne load?
I am SOOOO confused hmm
This is why i am so confused about all this also/...Just dosn't equate weight to weight in my way of thinking.
Time To Sleep Later In Life.
Your brake safe breaks won't operate until your van has left the tow vehicle and chains are broken,but (IF)the breaking strain of the D Shackles are 5 times the rated shackles and you have 3 tonne D Shackles on a 2.5 tonne caravan I can't see them breaking, it wasent me that quoted 5 times breaking, maybe the chains will break first.
Lance C
