Post Info TOPIC: 3 way fridge
3 way fridge
Hi all,
My fridge is 11 years old and is not working as good as it use to(like most of us).Do they need re gassing?? Seals seem ok.Cheers
goldcoaster wrote:
Hi all,
 There is no regassing as such, if it has a leak then it wont work at all.If the gases have leaked then its most likely better to replace the fridge rather than repair.
Some times a bit of rust/scale can block the tubes, the old trick is to take the fridge out & roll it around a few times turn it upside down for a while & retry unit.
If its a caravan fridge then you mat wish to have a look at this/ go to the search window & enter( who has put 12volt fans on fridges).posted by Blaze.
Then also enter ( some test results are in on fridge insulation). Posted by myself.
Mine is now working extremly well after to modifaction.
JC.
-- Edited by justcruisin01 on Friday 12th of April 2013 10:18:09 AM
JC.
Thanks JC,
I might start looking for a new one.
If you go for a Dometic one, don't get one of the round fronted ones. They are not T climate rated.
do you want to sell your old one and how much
snap
I will shop around and let you know, have your details. Also tossing up whether to upgrade the motorhome. Thanks for the offer.
