SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Electrolux RM 4401
Smelly fumey fridge [2 vote(s)]
Gas fridge smelly
0.0%
Electrolux Rm 4401
100.0%
Electrolux RM 4401
Hi  fellow travellers.
Just joined this sight. Great reading. Anyone had trouble with their fridge running on gas and smelling very fumey inside? Have cleaned the exhaust pipes, had a gas fitter check the burner and igniter..all good flame burning ok, no gas leaks. Not a gas smell, but ends up stinging eyes. Frustrating.... Help!!!
A.R Sheldon
I don't know much about caravan fridges, but could there some kind of broken seal, crack, etc within the body of the fridge? This would explain the smell coming from the pilot light behind the fridge.
Can you get a gas detector from somewhere and place it in the fridge and close it, to see if there is a leak. If all this is negative, it might be you have a really sensitive sense of smell.
Grams and Poppy
2003 Toyota Landcruiser Prado Grande
1999 Jayco Starcraft 15ft Pop Top
There should be no access for fumes from the rear of the fridge into the van.
The rear of the fridge should be sealed off, the fridge should sit in its own compartment, also all fumes from the gas heating should escape thru the vent on the right hand side of the top vent there is usually behind this top vent a small angled pipe to direct heat and fumes this can get out of place.
If it is an ammonia smell you have a leak in the cooling system and can only be repaired by replacement of the cooling system.
I think your fridge probably needs checking by a fridge technician that is conversant with absorption fridges rather than  a gas fitter.
When these fridges are new you will get a burnt paint smell for a short period till the dust and paint gets burnt away.
David
