Post Info TOPIC: PVC / VINYL Stone Gaurd
We are going to re cover the front of the Avan  (Stone Gaurd)   With Diamond Pattern PVC or Vinyl.
Anyone give us any tips re Fitting, Adhesive to use,  The amount of stretch,  if any to  apply.
We have no problem in doing the work, but would appreciate all the advice we can glean. Especially the adhesive to use.
Mike and Eleanor
Mike & Ellie
I have vinyl to do mine but like the sound of your PVC Where did you get it and whats the cost if possible. As for the right adhesives I have not idea but the stikaflex range should be a good start point in a search for one as they make a lot of glues for the Auto industry. Dear but good
Contact adhesive in a spray can.
 Cheers, Chris...
-- Edited by elliemike on Sunday 31st of March 2013 01:55:54 PM
Clarkes Rubber in Balcatta, W.A.  $44 per metre x 2metres wide.
We are using the Gunmetal coloured diamond pattern.
Looked through the Sika products, but not  seen anything that actually says use on  PVC.
I use Sikaflex 291 a lot both at work and at home on the van and various projects.
The thought is also, is there any glue used at all other than sealing the edges then fitting the clamping strips.  In the sun this stuff must expand and contratcs and stiffend in the cold.    Some of the contact adhesives I have used go hard and brittle  and may  create wrikling in the heat.
-- Edited by elliemike on Sunday 31st of March 2013 01:58:05 PM
-- Edited by elliemike on Sunday 31st of March 2013 01:59:51 PM
Mike & Ellie
Yuglamron wrote:
Like Chris said use contact adhesive in a spray can,you get a better coverage than brushing.
Make sure you cover the both the PVC and the front of the Avan and don't be tempted to put the two together too quickly, wait for the reccomended time.
Sometimes it's of benefit to make up a paper or card template to get your  best fit and then cut the PVC.
Trevor
 Have you used  contact adhesive to do this job.  What brand was it !
I will be taking the existing stuff off in the next week or two and will be able to see what was used originally.   But again many brains make light work especially in being prepared.
Thanks for all the input so far but keep it coming.
-- Edited by elliemike on Sunday 31st of March 2013 02:05:57 PM
Mike & Ellie
Yuglamron wrote:
It was 3M brand and I used it on the Vinyl roof of a car.
Like a previous post has said if you can get the edges under a strip top bottom and sides it will be much a better finish and stop the vinyl lifting.
I also found one of the usual car shine products like Armourall vinyl cleaner/conditioner kept it in better condition as well.
Trevor
 Yep the edging clamp strips are alredy there on the existing stone gaurd.
I will be using the  existing Vinyl as a pattern if it (I'm certain it will ) comes off in one piece.
As I said earlier  "Doing the job presents no problem"   Just need to verify what adhesive to use and any tips on fitting like strech  if any etc..
Thanks  Mate.
Mike
-- Edited by elliemike on Sunday 31st of March 2013 04:49:02 PM
Mike & Ellie
Trevor
Trevor
