Post Info TOPIC: Rodeo 3L diesel pump
RODEO TF 2002 3L pump.JPGDSCF0683.JPGDSCF0684.JPGDSCF0689.JPGFor Petengail, regarding Zextel (Bosch VP44) Injector pump & failur of spooling solenoid driver in the computer (engine wont run). Pictures of the pump i recently repaired, using IRFZ44H MOSFET & Arctic Silver (90% silver) 5min araldite to glue the MOSFET in place. 3rd pic down in the lower LH you can clearly see the aluminumn wire to the MOSFET is blown with 2 molten ends. The 4 pic top RH is the replacement MOSFET glued in place & wired up. Note these pictures were taken using Macro on the camera as every thing is quite small on the computer.
-- Edited by DeBe on Thursday 28th of March 2013 10:55:44 PM
D.L.Bishop
DSCF0686.JPGRODEO TF 2002 3L pump.JPGDSCF0683.JPGDSCF0684.JPGDSCF0689.JPGFor Petengail, regarding Zextel (Bosch VP44) Injector pump & failur of spooling solenoid driver in the computer (engine wont run). Pictures of the pump i recently repaired, using IRFZ44H MOSFET & Arctic Silver (90% silver) 5min araldite to glue the MOSFET in place. 3rd pic down in the lower LH you can clearly see the aluminumn wire to the MOSFET is blown with 2 molten ends. The 4 pic top RH is the replacement MOSFET glued in place & wirede up. Note these pictures wer
D.L.Bishop
Thanks for going to the trouble..... Cheers Pete
How long did your repair last please?
Thinking of doing the same thing myself.
Regards Richard
Its still being used as an every day driver, so far 4yrs. After the repair it took abit to bleed the system.
-- Edited by DeBe on Thursday 15th of December 2016 10:41:40 PM
D.L.Bishop
