Post Info TOPIC: Reversing camera for the caravan....
Heres one that might help:
[video=http://m.youtube.com/watch?v=EFZil9HhVKE&desktop_uri=%2Fwatch%3Fv%3DEFZil9HhVKE]
Ours comes already fitted, and a mechanic is installing the screen for us.
-- Edited by Grams on Tuesday 26th of March 2013 04:58:17 AM
Grams and Poppy
2003 Toyota Landcruiser Prado Grande
1999 Jayco Starcraft 15ft Pop Top
Can anyone recommend a model?? How tricky they are to wire up to the van.
Bought the one advertised at ALDI a month or so again but looks like it is going to be too tricky to wire in.
How much (roughly) would one expect to pay for a reversing camera?
Also...is there a camera that can be mounted on the caravan and it can be on while driving so that it shows traffic behind. (in other words, not just for reversing!!)
All info gratefully recieved!!
Buffy
http://kiwis-in-oz.blogspot.com.au/
If you are wanting to bye another camera ,don't bye a wireless type been there and dun that they are crap,bye a hard wired one ,I bought mine from the Melbourne caravan show about 5years ago from Saftey Dave ,back then I payed $410.00 for two camera,s and all the cable,s, and the monitor ,only trouble I have had was one cable packed it in,as far as leaving the camera on ,mine is on all the time I switch between car and van mainly on the van camera,I asked about leaving it on all the time and he said it can be left on it won't hert the camera,it is no different to looking in the rear view mirror,fitted mine myself if you are a handy man it is pretty easy to do hope this is of some help.
Lance c
-- Edited by Olley46 on Tuesday 26th of March 2013 09:53:26 AM
-- Edited by Olley46 on Tuesday 26th of March 2013 04:56:33 PM
Purchased mine from Elinz electronics Victoria, off the net. Cost $175 now about $200. Has 2 way switching 1 for reversing 1 for rear of van. Hard wired, would not use wireless system as signal can distort. I had to crawl around underneath to get the cable through but well worth the effort. I now don't use any "driving"mirrors only standard rear view mirrors (Prado) and have the camera on all the time while driving and have no blind spots anywhere. It is not illegal do drive without extra mirrors, only requirement by law is you must have clear vision behind & down sides. Camera wouldn't be with out it. Great investment.
Olley 46 wow you say you paid 4grand!!!!!!!
-- Edited by carpaidiem on Tuesday 26th of March 2013 04:03:42 PM
Got mine through Safety Dave as well.   I think it was about $350.  I got them to install it, came to my home and did a great job.  About another $300 for installation.   It has a colour monitor that suction cups to the windscreen and the rear camera has a mic in it so you can hear your off sider as they direct you back.  I also leave it on while driving and use it as a rear view mirror.
Hi Malcolm
Are you shore about not needing extra mirrors on your 4wd I have a Prado as well and wouldn't tow the van without the extra mirrors ,maybe my caravan may be wider than yours,I thought the law was if towing a caravan you must have extension mirrors regardless of camera,s.
Lance C
-- Edited by Olley46 on Tuesday 26th of March 2013 05:31:23 PM
Yes, I got mine from Safety dave as well, around $350 plus fitting of $230.
I turn the mike off when travelling otherwise the noise is too unsettling.
SWMBO likes it 'cos she doen't have to act like a semaphore and doesn't
have to yell at the driver.
Kevin
I used to be addicted to soap,  I'm clean now.
Try this website.
http://polarisgps.com.au/
 You have to navigate to Products on the top bar then to Extras and a window will load with another link for car and caravan two camera system @ $295 plus fitting.Any decent audio shop should be able to fit the system to your tug and van.
Hope this helps.
Trevor
A little bit expensive hay what ,a bit of a figure mishap,been fixed now ,it would want to have a good picture for 4grand,I am getting old sorry.
Lance C
I have had an Aldi camera for nearly 2 years now. Easy to fit and works great. I wired mine to the tail/clearance light on the van, so I just turn on the tail lights to use the camera.
Patto
Dodge Ram 3500.
NO FIXED ADDRESS.
re   thought the law was if towing a caravan you must have extension mirrors regardless of camera
In Sa if you can see with your standard mirrors down each side of the van you are not required to use extended mirrors and cameras are not recognised as being an alternative to mirrors
Patto
 Hey thanks for that. We are having some electrical stuff done on the van soon so maybe I should get them to wire in the ALDI one we already have. So if it is wired to the tail lights instead of reversing lights can we have it on while we travel and use like rear vision mirror (as others have described)
Had a freind fined $250 just last week here in SA for not having external mirrors that could see down both sides of his van.
D.L.Bishop
Hoo is wright the SA Police or the SA gray nomads as regards to Towing Mirrors.
Lance C
I to purchased an Aldi Camera,
Great, no problems with it & wired it up so i can switch it on whenever i wish, not just in reverse.
Miroku12g
Dave, Maz, Zac, & now Buster
We got our van today, and I asked the caravan guy about the legalities of not using extended mirrors and just the reversing camera and he said no way is that legal. If your mirrors cannot see down the sides of your van, then you will need the extended mirrors. The camera only shows you the back of the van not what is at the sides.
Also it was great to be able to turn the camera on while driving to see if there were any cars behind you on the road. The mirrors do this of course, but it's amazing to see it.
Grams and Poppy
Question: where do you locate the camera on the back of the van - high, low or where.....also is difficult to train the brain to turn the steering wheel when reversing via camera.
This is where I have mounted my camera.
Ours is in the middle at the top.
Grams and Poppy
Ideally the camera should give an image similar to what you are used to seeing in a rear vision mirror. Nearly all cameras flip the image so the left hand side of the vehicle appears on the LHS of the screen, this is vital.
 Cheers, Chris...
Simple rules to follow when reversing
1.Do it slowly
2. See to much in left mirror pull down to the left to come back to center or make minor corrections
3. Nothing happens fast so be patient, it will turn
4. Get a set ot small hand held radios  it will save your marriage .
5. If you lose it pull forward and start again
Like the pole mount no holes and can be relocated if you sell.  Thanks for the idea
I want to know if these reversing cameras are suitable to be on full time. I was about to hook up one through an Anderson plug tapped out of the accessories connection in the flat plug on the tug, any thoughts would be appreciated . I want to mount and use the camera full time
I powered my reverse camera on the van via the tail lights, when I wanted it on I just turned the park lights on, a lot less wiring to go wrong.
blaze
buffy61 wrote:
Patto
 Hi Buffy, Sorry for the delay in replying.
Yes, I travel with my tail lights on and this also activates the camera. Very easy to wire up. If you need help email me.
Patto
Dodge Ram 3500.
NO FIXED ADDRESS.
 I leave mine on all the time when travelling.
First time I used it was a bit unnerving to look in the mirror and see the road behind -- "OH SH!* I'VE LOST THE VAN". Took a few k's to get used to it.
Patto
Dodge Ram 3500.
NO FIXED ADDRESS.
 I can't see why not, basically they have the same internals as security cameras used 24/7. Vibration would be the only long term killer, and that is going to happen whether the camera is on or off.....
 Cheers, Chris...
Thanks people I have food for thought and a mass of good ideas to go on with
Could have used one today, backing the van into the garage I hit the wall. Just for fun it'd be cool to put a monitor on the back and the camera on the dash so they can see when it's safe to overtake.
