SmartBar Floriade Goodlife RV Resorts Celtic Fest VisitLockhart Camp Creative
Post Info TOPIC: caravan hitch
caravan hitch
Yep....!   I might splash out for a new one,   just for a safty  point,  the van is old   and not a H.R connection
Everytime I take the van out I am continually thinking about the connection
-- Edited by my van on Sunday 17th of March 2013 04:04:08 PM
Retirement is  when one makes the best of what one has got left.
   Paul    CENTRAL QLD.   Solo
I often wondred if the ball or the hitch on a caravan  needs to be replaced  after a few years  or if it is good forever . That joint is a very imporrtant   bit of equipment   .  I grease  it occasionly   . Can anyone tell me if there is a correct way or safe way of  checking the integrityof the ball and hitch .  maybe I worry too much  ? cheers  from  "my van"
I don't know of any way to have the Ball tested but at the price you can now buy them I thing the best safety test would be to replace it, If you are using a good quality hitch like Hayman Reece and have not bashed it around like some off-road 4X4 drivers I have seen then you would not expect to have any trouble with it, if only a cheap hitch I for reasons of safety be upgrading to something like Hayman Reece brand.
 Do you mean Ball & Hitch or Ball & Coupling?
OJ
 Hi my van
I change my tow ball every big trip,that,s me though we go away every second year fot three months,I feel that the ball has done it,s job I feel safer with a new one,some people never change them ,for the sake of $8-10 dollars is money well spent,the HR hitch head will ware a bit where the trunnions  fit in but will last a long time ,I thought  mine was worn pretty bad I checked it with a new one ,it is still  ok by the trailer experts, if you have a HR  WDH make shore you put dry lube on your trunnions and  grease your ball ,I lube the trunnions before every hook up,the trunnions are the t piece on the end of your bars,the reason for the lubeing is to stop wear and stop any rattles or clunks while driving  and turning.
Lance C
I couldn't agree more. Lube your trunnions and grease your balls I always say.
Gary
Have never changed mine in over 20 years. I did have one that came loose about 35years back, think there would be more chance of that happening than to ever have one shear off and that would have the same chance of happening with a brand new tow ball as an old one.
David
I have a chrome towball and when the chrome shows signs of wear I replace it. (signs of wear are chrome starting to wear off the ball )
As for the caravan coupling, before each trip I simply spray where the ball fits with WD40 wait a couple of moments then wipe the interior of the coupling where the ball goes.
I also give the ball a smear of lithium based grease. Pressure Pack type.    So far in 30 odd years no problems have occured.
Cheers Dodg.
