SmartBar Floriade Goodlife RV Resorts Celtic Fest VisitLockhart Camp Creative
Post Info TOPIC: Portable Electric Single or Double Hot Plates - Normal or Induction?
Duh
In regards to using portable electric hotplates, which is best, the normal type hotplate or the induction one? confuse
You pay a lot more for the induction one but is it worth it? confuse
PS:  I also have a gas cannister stove for use when not on power, but am not comparing with that.
I have a cheap induction portable stove which would be great for my van if on power. Ebay
Janette
I have a portable induction cooktop , It is great for slow cooking has well has high heat , You can get the heat level down to such a low heat without any fear of the food catching and burning would not be without it must have induction cookware to test if yiour cookware will work on induction you use a little magnet sing which stick on your fridge, if it stick to your fry pan on pot it will work on induction cook top
Duh
Thanks for the feedback Janette and Brickies, and the tip on testing the pots and pans for compatibility! biggrin
Duh
Sheba wrote:
Thanks for that Chris.  Now I know mine is a normal one.
 There are a few here to look at too Sheba, both types.....
http://www.productreview.com.au/c/portable-cooktops.html
and;
 http://www.shopbot.com.au/hot-plate/price/australia/504489
-- Edited by Duh on Sunday 17th of March 2013 02:01:08 AM
Mine is a cooktop rather than a stove but quite portable and cost me less than $50. Even cheaper now around the online Ebay and other traders. The fan is quite loud and I don't use it a lot so can't know about longetivity. My normal SS pots seem to work on it.
I still love the portable cartridge stove particularly when no power.
Janette
 need to have a magnetic base, test with fridge magnet, some stainless is magnetic
blaze
Duh
Thanks blaze, that was mentioned by brickies too.
jetj, I think I did read somewhere that the portable gas stoves heat better than the electric and a lot faster, thanks.
Vic I have a gas cooker has well the flame is a problem in the breeze and can take the heat away from the pan
 I have one at home I bought for about $60 have used it continually for almost 2 years and just love it, quick clean.  You do need the special pots and pans but they are becoming easily available I have non stick from Coles Wiltshire brand.
Judy
What is the difference between Normal and Induction please ?
 An induction hotplate magnetically induces heat into the cooking pan or pot. They are more efficient than the normal hotplate or element and the stove is cool to touch if there is no pot on it. You must use pots and pans that are steel, magnetic though...
 Cheers, Chris...
Hi Duh
Gas camping stove maybe less than 50 dollars the rest left over for refilling small gas bottle
would last you an very very long time
far more economical
regards John
Duh
Cruising Cruze wrote:
Hi Duh
far more economical
regards John
 Thanks John, worth noting...have taken it onboard aww
I use an induction stove in my bus.
One of the best appliances I have as it cooks stuff so quick and you can select the heat level you want. The only problem some will have is it starts at 1800w and it then has to be turned back so many will not have the inverter or the battery power to run one.
Would run of a 2kva generator though.
The little Bunnings gas stove are a great backup and the cost of the gas is very cheap. Get two if you want two burners or buy the Aldi one which has a double burner.
Brian
Duh
Thanks Brian, I already have a one burner gas stove, just have to decide on the electric one.
