SmartBar Camp Creative
Post Info TOPIC: So...15amp power lead to get 240v in the van....
.. I am currently parked in my sons backyard at Tweed Heads with my 15 amp 240 V power lead plugged into a 10 amp AMP-Fibian fuse box connected in turn to my sons 240v house power ..
have a look here ..
http://www.caravanandrvworld.com.au/electrical-generators-and-solar/ampfibian/rv-02-ampfibian-10a-15a-240v-portable-adapter
Buffy .. the drawback here is that you are limited to how much you can run on 240v at the same time as you are limited to only a 10 amp draw .. Its a matter of trial and error to see what works together ..
enjoy
Jon
-- Edited by biggles on Saturday 16th of February 2013 09:17:36 PM
    **  living life  **
A tad confused...
was sold a 15amp power cord for caravan when we bought her yesterday. We obviously want to plug her in at home and get the fridge to temp and test drive the bits and pieces. So...do we have to use the 15 amp power cord or can we use 10amp power cord? The pin on the 15amp is slightly bigger and I guess it doesn't fit into house power?
so tell me how you guys do this from home...please! Cheers
http://kiwis-in-oz.blogspot.com.au/
I had the same problem.  Go to the techies corner.  It is all covererd in that forum.  You can't use a 10amp outlet to power 15 amp.  It is illegal.  There are several threads.
Cheers and again welcome.  This is a great source of information for new old people!
Never growing old, just getting dusty around the edges.
Stand by for lots of recommendations but one is you could get a 15 amp power point installed at home for that use if that is only time you need it . But there is other solutions for your problem which I am not sure of but you will soon know about
Such bravery, starting a 15 amp extension lead thread! It will attract 73 different opinions (none of them helpful) and end in tears.
The short answer is: if ALL you want to run is the fridge, use a 10amp lead.
IF you also want to run the aircon, microwave, 150cm plasma TV, electric kettle, electric frypan, hairdryer, pizza maker and fan-forced oven as well, maybe you should look at the 15amp option (and/or a VERY big generator for when you go bush).
(Puts on flak jacket and ducks for cover).
Cheers, Tony
If you don't stand behind our troops, please feel free to stand in front of them.
tonyd is right, goodonya tony!
Tony can you put a 10 amp lead into a 15 amp socket on a caravan
 Yep, that is my question too, bricking!
any takers to answer that one!! :)
No Buffy, it doesn't fit. Basically there are two legal options. 1. Have a 15A power point fitted (usually in the meter box is the cheapest option) or 2. buy an Ampfibian adaptor which plugs into a 10A power point & has a 15A socket on it with a protective circuit breaker between the two. Number 2 is by far the best option if you're not retaining ownership of the house or intend plugging in at relatives/friends places at times. Love the van by the way. Good luck on your travels & hope to meet you out there somewhere. Excitement plus now for us as house settlement is three weeks away & still heaps of stuff to get rid of.
Darrell & Sandra
Love the bush & our native environment. Conservationist, not a bloody Greenie.
 No you can't as it won't physically fit, as the earth pin is larger
Darrell & Sandra
 Thanks for all your help. So far I am liking option no 2!! So where does one get the ampfibian adaptor? Rough idea of cost?
we are also storing caravan at a friends so don't want to change or add to their household power.
And thanks for the good wishes! Hopefully see some of you out there!
vicki and bryan
Dutchy it would be the small earth pin on the 10 amp lead going into the large earth socket on 15 amp receiver , Jon I beleive that 15 amp power does run off 240 v power the difference is the 15 amp lead is much thicker than 10 amp lead
Pretty sure Bunnings have them.
Darrell & Sandra
Jon has posted a link to a website click on it
 You cannot plug a 10 amp socket into the van it will not fit unless you enlarge the 10amp earth slot  in the socket of the lead, this of course is illegal, the 10amp lead is exactly as stated it is rated to safely carry 10 amps the 15amp lead can safely carry 15amps the lead for a caravan has a larger earth pin on both the socket and the plug.
Buffy 61 I have sent you a PM
David
Think the ampfibian is way to go! Will check and see if jayco stock them since we get 10% discount on any products bought thru them.
Cheers everyone! You answered my question!
No doubt I will have plenty more!
Ihad a sparky friend make me a very short power lead..
Male 10amp 'male' end to plug into my shed 240V,  and 'female' 15amp plug to fit the input on my caravan.
Is great for running the fridge and a light while getting packed and ready for next adventure.
Works a treat for me.
-- Edited by Ole_Grizzly on Sunday 17th of February 2013 10:28:18 AM
Kalangadoo with a wheel- barrow & Waterbag
If Jayco don't have one you'll find a list of stockists at http://ampfibian.com.au/suppliers/
Other caravan parts suppliers may also have them
Merda tauris scientia vincit
I use the "Ampfibian" as I was told you are not covered by insurance if anything goes wrong. The first thing they check is how you were connected to power.
I bought an Amphibian from Jayco in Perth 10 months ago $150.
I also have a spare lead to use with Apmfibian which is 15 amp lead with 10 amp plugs , I still think using a 10 amp lead to the Ampfibian then going into 15 amp lead dosen't add up to me
 duck for cover
Thanks everyone! $150 from jayco sounds cheap cos the cheapest I have found so far is on eBay at $220! Will go for a wander at Bunnings and report back for other newbies! :)
I had a 15 amp power point installed in the meter box, cost me $160 and allows me to run aircon etc legally, safely and without problems.
Santa.
Just thought I might throw in my 2 cents worth ,after being in the electrical indrusty for over 50 years and I hear of people who would risk life and limb for a few dollars having a lead made up with a 10amp plug on one end and a 15amp socket on the other with no protection in between is not only dangerous but highly illegal ,the adaptor that is available is supplied with a 10amp lead and plug and fitted with a 15amp socket,but in between them both is a 10amp circuit breaker which protects the 10amp cable and plug so it does not matter what you plug in you cannot draw more than 10amps and the unit will keep tripping till you reduce the load if you exceed 10amps ,so there by protecting the 10amp cable. So there is only 2 viable options if you want 15amp supply at home install a 15amp outlet or if you have a problem on the road with a 10amp socket only available get yourself a proper adapter
regards
peter m
Just to maintain a battery charge, or to run your fridge and a light for pre depature I still find and still will use my 10/15 double ended short power lead.
Probably not safe as mentioned previously, but without overloading the circuit, the amps are so minimal and will keep using mine while loading for my getaway.
It's OK, throw the pot's and pans at me lol, but suits my needs...cheers
I bought my amphibian from their site and got a limited edition red one. Most of my stuff is red, including the new XTrail I have just bought. I had a lead with a 10 amp one end and a 15 amp the other which was made up by a friend but I only used a couple of times but then ditched it because you are in BIG trouble if anything goes wrong. You will null and void your house insurance and your trailer insurance as well as being charged by the fire department because of its illegality. I only ever used mine to charge the battery up while I was at home as a friend (the same friend) put a caravan outlet on my little camper trailer as he felt that leads just running into the tent were dangerous and a hazard particularly if there were kids about.
Bowlerbear (Chris)
Red XTrail with an Elite Sprinter Camper Trailer
We had a 15amp power point put in the meter box but I think Buffy61 has sold the house - so Ampfibian sounds the best. I'm glad they asked as I didn't know you could get such a thing. Sounds very good.
NeilnRuth
Duck for cover as much as you like OleGrizzley but kiss your a**e goodbye if anything goes wrong. Your insurance company will think you're the greatest thing since sliced bread. Only been in the electrical game for 45 years (dealing with insurance claims off & on for most of them) but you go with your mate. Hope he covers any damage for you if it occurs
Darrell & Sandra
It's all getting a bit boaring Darrell..lol
But I get your drift and thanks for the 'heads up' and will give me ole mate a buzz and see about a 15amp setup.  cheers
