Post Info TOPIC: swift 500 cooktop not lighting
just tested cooktop so we can go away for a short trip
i have gas reaching hobs (i can light them wth a match)
when i depress the piezzo switch i only got intermittent clicks to start with ,but this has now stopped
i seem to have power at the switch (when removing switch if i let it touch the body of the cooktop i get light sparking)
the handbook refers to 500 series with battery opp ignition but i cant locate any battery holder and it seems to me that there is 12v power wire to the switch
i dont have fuses in van only self setting relays
any suggestions as to what to check
brian
just had a second thought, i believe there should be a relay/activator between the switch and the hobs.
any clues to if it is servicable/replaceable
brian
TAJ
friend had a jayco no battery in van had to have 12 pin plug connected to car
hope this works
thanks taj
i have battery in van and power to cooktop switch
i am beginning to think the piezo is faulty
brian
