SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Road worthy ??????
Road worthy ??????
Hi once again I know I am bombarding you all with questions...... But...... When we buy a used caravan privately do we have to have a roadworthy? Is it like buying a car? Thanks once again my new found encyclopaedia of caravanning knowledge. Vic
The rules would be different in every state, don't think it is a requirement in NSW
Not sure of the answer for that but we are in the process of buying tow vehicle and have organised mechanical pre-purchase check.
Did notice that they check caravans too so maybe for peace of mind you might want to do that.
Vicki
http://kiwis-in-oz.blogspot.com.au/
I think to change rego you need electrical and gas certificates
bla\e
If you say which state you're from you'll get responses that are more relevant to your situation.
In NSW a roadworthy is required every 12 months and in the case of cars etc (and to the best of my knowledge, caravans too) when the vehicle is being sold, the vendor being responsible for the certificate.
Note that a current registration certificate does not confirm title, you'll need to do this research yourself.
If check the relevant website of the registration authority in your state you should find the answer there.
Merda tauris scientia vincit
no roadworthy required in Victoria (as per Vicroads website)
SOME  POLITICIANS  AND  BABIES  NAPPIES  SHOULD  BE  CHANGED  OFTEN FOR  THE SAME  REASON.
We had to get a roadworthy("Blue slip") when changing rego from ACT to NSW, and it was a big hassle as they noticed the tare weight on the ACT rego slip was 300 kgs more than on the compliance plate! the Dealer had registered it when new, and we never checked the weight stated on the slip. So we had to empty the caravan, including draining out all the water, and take it to a public weighbridge. The compliance plate is correct.
Once the correct tare weight was established it was no trouble to register the caravan.
Lesson... ALWAYS check the documentation against the compliance plate when purchasing either a new or second-hand caravan!
Cheers,  Gerty. ... at home
In Qld to transfer or register, you must have a "Safety Certificate" for a motor vehicle and the same for a caravan. If the motor vehicle or the caravan has gas fitted then you must also have a gas certificate.
It is only required when transferring rego. No annual inspections.
I don't know whether we've helped the original poster or not. She has not come back to the thread to either let us know which state she's in or even if she's read the replies.
Bought a 1970 Viscount and no road worthy required.
The best view of the city is in my rear view mirror
                         ( LOFFTY )
                              :twisted:
Ni$$an Pathfinder, roof top tent & / or Viscount 1970 Van.
No Roadworhy checks apply to light trailers (Caravans) in Victoria, but the vendor (In all States) is responsible under consumer law to supply goods of a "Merchantable Quailty"and  "Fit for Purpose" and thus should be supplied in a Roadworthy condition.
Ozjohn.
-- Edited by ozjohn on Friday 25th of January 2013 09:12:52 AM
Sorry guys.... I am in Victoria. Thanks heaps for your replies. Looks like no road worthy needed. Vic
