SmartBar Floriade Goodlife RV Resorts Celtic Fest VisitLockhart Camp Creative
Post Info TOPIC: A GREAT RESULT; RE, TECHIES CORNER; FRIDGE INSULATION.
It's on my to-do list.
Thanks for your input to this topic
Jim
PS: I agree with all the comments about caravan/RV manufacturers not installing the insulation. It's hardly a high cost item in terms of the initial cost of the insulation or the labour involved while the van/RV is being built. It would be a good selling feature for the marketers to promote.
-- Edited by jimricho on Friday 18th of January 2013 06:15:53 PM
Merda tauris scientia vincit
Many of you may have followed the thread in techies on 12 volt fans fitted to fridges, which ended up being closed.
If you did then you know that I done the recomended installation as set by Waeco , to which I then posted that I had some very good results, available via PM/email to which I supplied to many members.
I am now recieving some very good feedback from people who done the same job with insulation & are now more than happy with the results. I think we can say that the failure by caravan/motor home builders to do this insulation under assembly to be a contributing factor to the ongoing problems that have plagued many people with poor fridge functions.
For many years we have seen vans with air vents removed, sun shades erected over fridge areas & so on. As many alloy clad vans the cladding is the last to be fitted, it would so easy for these builders to fit the insulation prior to cladding.  I managed to do the job in an hour.  As for costs, to do it during assy would be minimal on a unit worth thousands.
JC.
JC.
Hello Jim
I have put the insulation in and also a couple of fans and i'm not sure of the results yet but will find out
At greens lake and it is very hot, the water has been a relief ,,,digressing a bit
Ken
DUN WURKUN
The Happy Helper
Good work JC - a lot of happy people, thanks to your ingenuity and help.
jules
(Ben, aged 10)
thanks for the email Jim have put the fans in so far not able to test it out
but I let you know as soon we get away with the van
I missed this post can you send me the details as I am about to go down the fan fitting road to improve my fridge cooling saga
Many thanks
Deadly Dave & Princess Judy
Fernvale Qld
Many thanks
 I have PM them to you.
Thanks;
JC.
JC.
