Post Info TOPIC: TEKONSHA P3 brake controller;
How many are using this unit & your opionion of it ?
JC.
JC.
I have had one for about 1 year - installed myself and had no problems at all. Brakes are smooth and progressive in application. Instructions supplied are adequate and there is heaps of help at Tekonsha and the web if you need it. So I'm very happy.
KFT
I installed one 3 weeks ago. only towed a short way to set up my hitch with the new tug but all seemed to work ok, set up was easy enough.
frank
Avagreatday.
 Hi  JC,   Had mine in for about a year and about 1200 K"s.  So far it has worked perfectly.
Also found it easy to fit
   Dave
Installed ours along with the monitor required in NSW myself, Jim.  Easy job, even on the BT-50.  Only done Nowra - Gulgong plus a couple of shorter runs with the van on but really happy with it.  Normal braking is smooth & progressive plus a trial emergency stop worked well.
Darrell & Sandra
-- Edited by oldboar on Saturday 12th of January 2013 07:42:00 AM
Love the bush & our native environment. Conservationist, not a bloody Greenie.
Terrific, better than earlier models, purchased mine through ebay, kit including wire cable, fuse, etc for $195.00 delivered. easy to fit and works great on the new van.
Deadly Dave & Princess Judy
Fernvale Qld
Great, bought mine from ebay for $195 delivered to fernvale, complete with all wireing, fuses cable ties etc. Opperates great smooth and easily adjusted on the go.
Fernvale Qld
I installed a Prodigy a few years back and I'm very happy with it. The Prodigy is similar to the P3 with a few less bells and whistles. The Prodigy may be no longer available having been superseded by the P3, not sure.
Merda tauris scientia vincit
Installed ours myself, Jim. Easy job, even on the BT-50. Only done Nowra - Gulgong plus a couple of short runs with the van on but really happy with it. Easy to use/set up and braking seems smooth & progressive.
Darrell & Sandra
Hi Jim.
We dont have the P3 but have the Prodigy the one before and I'm very happy with the performance far superior to the Voyager we previously had.
Easy to connect as a replacement as the wiring colour coding is the same so virtually just a swap.
Regards Jim
No problems at all exept i have to adjust the brakes regularly because of the weight im pulling
ITS NOT THE DESTINATION, BUT THE JOURNEY
G'day JC, after checking numerous reviews, forum member posts and asking around it got pretty good reports and so I had one installed. It works as advertised and I am very happy with it and happy to recommend it.
ozi2
Same as all the rest, self installed quite easy. Hardest part was getting to the brake wire under dash, we have had no problems so far (touch wood).
Cheers Sue & Stevesmile
Darrell & Sandra
Darrell/Sandra, what is the monitor you must have in NSW - you don't mean a breakaway brake cable thingamijig?
Thanks   Denis
Thank you for all the positive replies, I had been considering a new unit & this sounds like its the way to go.
JC.
JC.
Yeah, Denis I got a tad carried away. The monitor is for the Brakesafe unit & indicates the Brakesafe battery condition every time the brake pedal is applied if the van is connected.
Darrell
i think thats the same as mine jim i love it
by the way the bars finished did it this weekend were christening it rite now bar meal and drinks
dibs
gdyble
dibs
 Will check it out next time we are up your way. LOL.
JC
JC.
hi jim that 1 i got is a primus iq 90160
dibs
gdyble
