Post Info TOPIC: 3 way fridge
3 way fridge
How do you remove the 3 way fridge in a Viscount caravan
do you only have to remove the screws in the front surround panel or do you have to do more,
is there maybe a website that shows you how to do it
any help would be fantastic
There are screws in other places in a few. Do you still have the operators manual for it? The installation instructions are in it. If not, supply us a model number we can chase up a handbook.
 John, If this relates to the work I done here I did not remove the fridge, was able to do it all from the two air vents. RE- 12volt fans( closed)
JC.
JC.
First of all Thank you Peter D
silly I've dowloaded one a while back when I've got the caravan ,
but never gave it a tough Peter
Thanks anyway
@ justcruisin01
will talk to you when you back in a week of so JC   thank you
enjoy your time away mate  best wishes
thanks for the photo's
Dunno if Cruising Cruze got the answer he/she wanted but if not you will find 2 or 4 bolts under the floor which hold the base of the fridge to the floor (2 or 4 depending on quality of instal). They will probably be either rusted or coated in bitumen. Also need to disconnect 12V wiring and gas line.
if you want to remove the frig from the van check to se if it will fit thru the door otherwise take a window out
Thanks for your reply Hako and TurboPete
