Post Info TOPIC: DC Question
DC Question
I hae an LCD Monitor which runs on 19v DC. What's the easiest and least expensive way to run it in my Camervan which is wired for 12v and 240v.
Terry
-- Edited by tcp99 on Wednesday 14th of November 2012 02:16:37 PM
Towing a Chief Arrow with a Colorado LTZ (All by Myself)
I assume that you want to power it with 12v DC, otherwise you could just use 240v AC as you do in a house.
Try Jaycar Electronics www.jaycar.com.au
12v DC to 19v DC (or multiple voltages) prob under $50
another way to do it is a 12v DC to 230v AC inverter. a lot more expensive but if you size it big enough you can run other mains power devices from a battery depends what size wattage but in the $000's
There are 3 types of people in this world, Ones who make it happen, the second who watches what happens and the third who wonders what happened
Make it happen
 They call them notebook or laptop power supplies. This one may do - http://www.jaycar.com.au/productView.asp?ID=MP3479 - if you are looking ahead and eventually want to power your portable computer from the vans battery there is a selection here - http://search.jaycar.com.au/search?w=laptop%20power%20supply
I own and regularly use a Jaycar MP-3324 http://www.jaycar.com.au/productView.asp?ID=MP3324.
It has sufficient "grunt" to power all but the most power hungry laptops. It comes with a range of connectors and voltage options to suit most laptops
Price is $59.95
Merda tauris scientia vincit
Thanks for the suggestions. Went to Jaycar and purchased one for the monitor and one for the laptop.
Terry
Terry
 You're welcome tcp99, I went to Jaycar today also for other parts, as I've done often in the past.
Good range of electronics stuff is mostly always at Jaycar
Make it happen
