SmartBar
Post Info TOPIC: satellite info
satellite info
Apparently in their wisdom (without any prior warning) Optus decided to change the frequency.  Anyone with an Alden auto sat dish & having trouble this is how you reprogram it.  Switch off with central switch.  Switch on, pressgreen switch until 2  green lights show then switch off again.  Switch on,  press green switch until 3 green lights show.  Switch off again. Now programmed to D3.  Can now search for & find D3 satellite.  Hope this helps.  Apparently sat C1 is not being used now.  Any more info required please feel free to ask
My technical adviser (husband) made a small mistake when writing out info for me - After first switching off & then switching on you should then press red switch until 2 green lights show. Then switch off again. Switch on & press red switch until 3 green lights show. Switch offf again. . Sorry if this confused anyone
Thanks for the info Kandagal.  I hope ours is that easy to do when we get around to it. We are not on the road at the moment and the van is in the shop for a service and some warranty work.
     Landy
Are you on your way sth down the coast? If so can recommend glasshouse mtns cobb n co campground and we are like
2 min drive from there :)
glassies
Master (of Mischief)
is this the same for the VAST system?
that runs off of C1
OK guys, I just contacted Phillip @ http://www.satplus.com.au/ and he said "as long as you have a 10700 LNB nothing needs to be changed."
so VAST system's will work as usual.
-- Edited by _wombat_ on Thursday 15th of November 2012 12:18:28 PM
googled that and looks like a nice place,,not too expensive
