Post Info TOPIC: Plastic taste in drinking water
Thanks for the tips biggrin I will try bicarb soda. The tank is filled with the food grade hose and all hoses to and from tank are food grade hoses..confuse
-- Edited by Pinto on Sunday 14th of October 2012 07:41:42 PM
Harry @ Angela
G'day all smile I have fitted a 3rd tank to my Avan for drinking I was wondering how to remove the plastic taste from my new  water tank. We have flushed it out 5 times , put vanilla flavouring in it but still the horrid plastic taste remains. Any suggestions ?? The other 2 tanks are for creek-dam water for washing- shower but had no plastic taste when new... All 3 tanks are the same brand 95 liter tanks....
Harry @ Angela
If the twin tanks are not used for drinking water you could swap one of them over with the new tank.
The Master
Try Bicarb of Soda (Baking Soda) I use it in my van tank as do a lot of other nomads. Leave it in for a while and rinse the same as you are doing with vanilla.
It won't hurt if a little is left in there as it is drinkable anyway.
Happy Wanderer
Don't worry, Be Happy!
Are you using a quality 'Food' grade hose that complies with Australian Food Safety Standards, or a garden hose to fill the tank?
OJ
Harry
If the bi carb doesn't work, add heaps of salt (1/2 large container you buy at shop) dissolved in hot water before adding and then fill tank.
Leave overnight and rinse till not salty.  This works in our ute tanks when we haven't used them for ages.
Cheers Baz
Bi carb worked :) Put 1 packet in the tank and let it sit for 2 days... drained tank and refilled . Cuppa tasted GREAT :)
Harry @ Angela
The Master
Great news Harry. A excellent recommendation for others as well.
Happy Wanderer
someone on "another forum" used red cordial with great sucess
Jenny and Barry
you'd be pretty hyper after drinking that much red cordial though. Personally I'd fill it with bourbon... wouldn't taste any plastic taste then... hic.
Pinto
Your problem may not be the tank.   I most likely is the hose your using.   DON'T use a normal garden hose.   Get a good potable water hose.
Bunnings have one, (Light Blue) 10metre lengths long.   It is a common fault with caravanners new to the GN life style.
Happy Caravanning
