SmartBar Camp Creative
Post Info TOPIC: telford cassette toilet leaking from the top
Hi there all, every time I take my cassette out of the van to empty, it leakes all over my legs and feet, it seems the seals are gone on the couple of openings on the top, I have been using citric acid for descale hope that has not stuffed the seals? can one buy new seals or do I have to spend $150 for a new cassette?
"If you don't know where you are going, any road will get you there".
 Lewis Carroll
gst
You should be able to get new seals and if you follow the directions they are not hard to fit Regarde gst
We bought new seals from Camec in Perth. Can't remember the price now but they weren't very expensive. And were easy to fit.
Sue and Phil
msg
This may help
http://thetford.kpnis.nl/upload/132850_622_1252314250185-3_Complete_Repair_Guide.PDF
Sorry can't seem to make it a link
msg wrote:
This may help
 It's a link now...
-- Edited by vk6tnc on Monday 15th of October 2012 01:02:26 AM
 Cheers, Chris...
Thanks for that guys, will check it all out.awwawwaww
 Lewis Carroll
msg
This may also be useful. I was a bit sus with it being an excel worksheet but the guy in canberra was OK.
http://thetford.kpnis.nl/web/show/id=117011/langid=42
Thanks vk6tnc
Thanks for all the work all the links above work well when you copy and paste.biggrin
 Lewis Carroll
The Happy Helper
Re using citric acid in your cassette - should only be used occasionally, not as a regular thing - if you are getting crystals all the time, maybe need to have a pathology test!!!!!
jules
(Ben, aged 10)
Yes thought of doing that but it will cost me a lot of money the doctor said and not only that they would have to use the umbrella trick.
 Lewis Carroll
