SmartBar
Post Info TOPIC: Reel for extension lead
The Happy Helper
Saw an ad somewhere the other day for a reel to hold extension leads.  It was two discs together, that kept your power lead neat and tidy - yellow in colour, had a video on how it worked - does anyone know what they are called, and where they are available - I can't find the site - have googled but no luck.
jules
(Ben, aged 10)
Duh
Bunning sell them as far as I know, but be aware that the cord has to be fully unwound when using, otherwise it can catch fire from heat build up......Any cord should be fully unwound when using.....
Duh wrote.
Good answer Duh, Very important to fully unwind, ? especially if putting under load with a Generator or similar.
IF IT IS TO BE !! IT IS UP TO ME !!!
Maybe this is the one your referring to http://www.cordpro.com.au/
Ron & Shirley
www.ronshirl.net
amazon have that one for about $17
Rosie
The Happy Helper
Thanks for the input guys - knew I could count on you. And Duh, always know to have cords fully unrolled - though it is sometimes a pain in the butt!! Quite often see cords still wound around reels attached to van and power outlet - always think that it could start a fire or something, maybe short out the caravan power system. Again - thanks. Will look on amazon as well.
jules
(Ben, aged 10)
Duh
Knew you would be full bottle Jules (albeit surrounded by a few empty ones now and then like all of us wink biggrin)
Hope you manage to find the one your after !!aww
The Happy Helper
Yep, I did - might look into getting two - small one for the sat tv cord - which is long - and a larger for the extension lead. There were some mixed reviews on the site for them, but the most damning one shot themselves in the foot, by saying the cord got hot while using it half pulled out - shorted out their air conditioner etc., - apparently the instructions tell you to ensure cord is fully out of the winder, as several people pointed out to the complainer.
And Duh, I always feel that I would like to say something to caravaners etc., with cords only party unwound from reels, but bit wary of being seen as a busybody - I just thought that it was common knowledge that you unwound a cord fully.no
jules
(Ben, aged 10)
JRH
 Common knowledge and common sense seem to go hand in hand and there is not a lot of common sense in the world today.
If I don't get there today, I'll get there tomorrow or the day after.
John & Irona..........Rockingham Western Australia
The Happy Helper
JRH - that was a commonsense answer!!!!!!
jules
(Ben, aged 10)
JRH
 Thank you for the compliment.
remember those handline holders for fishing with the v at both ends?----i made one 3ft long and 12 inches wide out of 5 ply then wraped cord around it, it lies flat and fits nicely in storage compartment at rear of my unit. last in first out.
The Master
I have something similiar to what Kevin is describing only it is plastic and bought from Bunnings and only a bit over a foot long. It is orange and didn't cost much and lies flat in the bottom of the cupboard. It has little hooks for sticking the ends under so it doesn't unwind.
Happy Wanderer
Don't worry, Be Happy!
The Happy Helper
Yep I had one of those that you have HW - but got lost with a lot of other things along the way -getting a lot more organised in my life now.
jules
(Ben, aged 10)
If you need a longer lead use a hose reel winder instead. I bought one from Bunnings and made a 100 metre heavy duty roll out lead for a water pump.
www.squidoo.com/camping-in-queensland-australia
The Happy Helper
That's a good idea Willow -
jules
(Ben, aged 10)
just get a small car rim, you may even be able to fix it to the wall of your storage compartment
The Happy Helper
So many good ideas!!!!! Thanks guys!
jules
(Ben, aged 10)
