Post Info TOPIC: Satellite dish on the roof
Hello all, I am now completely self contained and nice and snug after having gas heating and solar panels installed.  On these long cold chilly nights it would be nice to be able to turn the TV on, if only for a bit of company.  Unfortunately there aren't many free camp sites where a TV signal is available so I am thinking of stretching the budget even further and having a satellite dish installed on the roof.  I know they are very expensive so I was wondering if anyone who has had one installed can tell me if they work well, and if it would be worthwhile.  Also where I could get one installed.  I am currently making my way towards Mackay.
Janno i dont have a roof dish ,i have a portable one nd use the vast system and you can get TV anywhere in OZ
KFT
you need to remember that if you seek shade then you may well block any sat signal you might need.
I have been using a portable tripod system for 10 years and would not change it despite the "easy" set up of an auto roof mounted system.
I can place my tripod in a spot where I can get signal and still have the van in shade, try doing that with your dish on the roof!!!
just my experience
frank
Avagreatday.
Hi Guys what kind of prices would you be looking at for Satellite dish? Portable or Fitted?
thanks
hi valnrob
we bought a portable dish last december for $500 with the vast system ,its great and we can get lots of channels
john & kay
KFT
g'day musketeer
that price I hope was for a complete kit?
you buy a dish (85cm) for $79
LNB $30
cable $20
sat box with card (vast) $299
Tripod $150
+ freight ???
all quality items no cheap stuff
the place is www.satplus.com.au and the back up support is free
frank
Avagreatday.
Often you have to move your dish around to avoid tree's blocking the signal.   We nearly bought a roof mounted unit but in the end we got a self searchig free standing one, and we are very glad we did.
   Landy
satplus is where we bought ours with great after sales service,we heard that there is a sat finder which just picks up one satellite which is the one you need so there is no searching through all the other satellites up there ,so check that out with satplus as well,good luck and enjoy
-- Edited by musketeer on Thursday 5th of July 2012 06:04:27 AM
john & kay
 To answer the OP's question, yes the roof mounted dish is very good and can cost $2.8 - $4K.
As mentioned these guys are in Mackay.
Some will say they are no good as "you can't park in the shade!"  Well, I say "why did you put solar panels on the roof if you wish to park in the shade?"  confuse
The panels and sat dish will probably give you enough shade anyway.
Go for it I reckon. You won't regret it.
There are free apps for android & iphone that let you use the camera to see if there are obstructions to the signal.
Cheers Neil
-- Edited by Delta18 on Thursday 5th of July 2012 11:11:45 AM
-- Edited by Delta18 on Thursday 5th of July 2012 11:13:49 AM
Neil & Lynne
Pinjarra
Western Australia
Master (of Mischief)
Satplus are great, ask Philip in Victoria any question, they are very quick with shipping items. http://www.satplus.com.au/
KFT shade will not stop a signal, tree's will.
musketeer, there is only one satallite (C1) once you have the signal no need to move the dish to get other channels.
Roof mounted dish is about $3000-$4000 then you need the rest of the gear, I would recommened a tripod system, same as Landy (about $500)
The new vast decoder now has a record function for an extra $60 you get another remote control ( and don't we all need another remote control) this comes with a code you put into your decoder which allows you to record a progrm, but it will only record the program you are watching, best used it you want to go down the pub for a meal and do not want to miss home and away, then you can watch the program you recorded while taping another program to an external hard drive.
BTW Janno, welcome to the site
I would not be without our vast system, keeps Mrs W quiet for hours biggrin
Here's the sat finder I use, most sat finders are crap
http://www.ebay.com.au/itm/3-5-LCD-Digital-TV-Satellite-Sat-Finder-Signal-Meter-Station-Platform-/280899132158?pt=AU_Television_Accessories&hash=item4166e49afe#ht_4215wt_913
most sat finders need somebody inside the van to shout out "OK YOU GOT THE SIGNAL", this unit uses one lead from it to the dish and you get the signal on the screen of the sat finder, you then connect the cable from the decoder to the dish direct.
You will also need a GOOD compass.
landy wrote:
Hi Delta 18 would you hapen to have a name for that app.
     Cheers   Landy
 Hi Landy, the app is called Wikicamps Aust, not only does it hava a compass designed to point to our satellite, the camera can 'visualise' it in the sky against your surroundings to see if a tree for example will be in your way.
It also, as the name suggests has heaps of user updatable free camps.
See it here.
Also available for iphone / ipad, same price.
My mistake, it is not free, it is $1.99.  Well worth that as you do not need a Sat Finder if you have the app.
Cheers Neil
-- Edited by Delta18 on Thursday 5th of July 2012 04:23:20 PM
Neil & Lynne
Pinjarra
Western Australia
If you area heading for Mackay, go and talk to Richard at Aadvark Electronics, he does a lot of Sat stuff.  (he used to be our opposition, but a really nice guy)  I am sure he will put you on the right track.
Cheers!
Chris
KFT
Hey wombat
I was wondering about this
"KFT shade will not stop a signal, tree's will." have you ever noticed that in most parks and camps it is trees that cause the shade?(lol) that is what I was referring to I should have made myself a bit clearer about that.
you have a great day
frank
Avagreatday.
KFT wrote:
Hey wombat
frank
 Hi Frank, I thought you were meaning if the dish is in the shade, all clear now, in free camps I can usually move the dish a long way away from the van.
One more thing with vast you will need to register as a traveller, that will allow you to re-register within the state you are in (Vic, WA or QLD etc)
     Cheers   Landy
Thanks Neil,
  I am still working out some of the things my smart phone can do but that is one I will certainly be looking into.
   Thanks for the info     Landy
Hi Janno Kay and I had the tripod type of Sat TV, but we found we were to lazy to put the thing up for a one night stop over while we are travelling around this great big country, so while in Adelaide we had an Alden fully automatic system installed by Dario's, they did a great job and we are very happy with it, yes it cost a lot $4000, but worth every cent of it, we have since travelled the Nullabor twice, up western aust, then the eyre penisular and then up the red centre to Darwin and we have had TV all the way, plus we have our Austar box with us so we have had the best of both worlds
Cheers Kay & Dave, & Penny
Hi Hydeeho, we have just purchased a van which has an Alden Sat dish mounted on the roof but we no instruction manuals at all, do you know where we can get them as we don't have a clue :( Thanks
Google the words
alden+satellite+dish+manual
gives several links , including to PDFs
We had the portable system and loved it. Then hubby decided to install a roof top system himself. I didn't think we needed it but am now so happy that we just pull up and even I can push the button to get tv. I recently bought a tv with inbuilt vast receiver so we could do away with the box and cables. Very happy with our toys.
