Post Info TOPIC: brake set up ba ford ute to pop top van
biggrin  hi guys, just found out my ute has a 12 pin anderson plug set up.  I Did"nt know as I bought ute from car dealer. my question is do I still need separate electric brake set up as info on anderson plug saysit has a service brake pin as part of plug setup. Ta confusedhmm
 Seano, for a start the 12 pin plug is not called an anderson plug, its a 12 pin trailer plug.
Both the 7 & 12 pin plugs have a pin for electric trailer brakes, BUT the trailer brake controler must be fitted to the tow vehicle for this to work.
Your vehicle may have a control unit fitted, if so it will be mounted some where around the lower dash / console area. It must be in a suitable accessible position where you you can reach it safley to adjust the brake bias between the tug & van, &/or be able to manualy apply the trailer brakes.
The 12 pin verses 7 pin allows you to fit more accessory circuts, reverse camera, etc.
A 7 pin on the van will plug into the 12 pin on the tug as these connections are the standard lights/ brakes & negative requirements.
JC.
JC.
biggrin  thanks jc with that sorted I can get the electric brake controller as suggested to me on previous grey nomads forum, ta seano  smile
Just to sort out any confusion this is what an Anderson plug looks like
Merda tauris scientia vincit
Go to this page - http://www.campertrailers.org/trailer_wiring_diagram.htm - you will see the pin connections for all the trailer plug/socket combinations (some apply to heavy trailers.)
