check out the new remote control Jockey Wheel SmartBar Topargee products Enginesaver Low Water Alarms Red Earth Festival Hammervan Park Booker
Post Info TOPIC: 240 Volt Fluros
240 Volt Fluros
It is possible to change 30 Cm.240 Volt fluro tubes with LED tubes
They are around the $30 mark
However you have to remove the ballast and gubbins and run them directly through the on/off switch only.
Not sure of the legalities of doing this yourself but it can be done.
I do know one of my best purchases was the Halogen spotlight in the rangehood/extractor that I was always burning myself on.Converted that to LED and now no burns.
There are a few companies that supply them that I know of and one is Sinfin Lighting on the Sunshine Coast in Qld and another is Peninsula RV's on the Mornington Peninsula. Both found on Google of course.
Hope this helps those who want to convert to LED's
-- Edited by Yuglamron on Friday 1st of June 2012 11:01:16 AM
Maybe you should have posted this in Techie's corner. I'm sure someone will know though.
NeilnRuth
Apologies,you are right ,however it was in response to an earlier post Re LED's for Vans.
