Post Info TOPIC: UHF Expert required please
Hello rockylizard
Re: Radios;
1.   Get the GME, Aust designed and made, parts are available.   I have had my second handle GME 5 Watt vehicle mounted radio for 14 years and have had no problems.
2.   Icom would the next choice.   Made in Japan and reliable.
I'am not sure about plug in charging or external aerial.   You may have to purchase an attachment.
Get an 80 channel radio.   Don't get a 40 channel, they will be useless by 2017.  You will able to transmit to an existing 40 channel set up using the 80 ch radio.
Cheers,   Brian
-- Edited by Two Strays on Tuesday 22nd of May 2012 03:18:16 PM
-- Edited by Two Strays on Tuesday 22nd of May 2012 03:19:01 PM
I currently have a 1-watt handheld UHF 40 channel CB. I am now contemplating updating to a 5-watt handheld 80 channel unit.
I am looking for a CB with at least the following features - 5-watt, ability to charge the handset in the vehicle 12v socket and the ability to connect to an 'external' antenna (one mounted on my bullbar) when in the vehicle.
I have done a bit of research and have found the following - UNIDEN UH076SX-NB, GME TX6200 and ICOM IC-41W.
A) Will either of these meet my criteteria above?
B) Does anyone know which is "the better/best" unit?
C) Are these compatible with the 'old' 40 channel units? (ie - will I be able to receive and talk to a 40 channel unit)?
All advice welcome.
I understand what you are saying about hand held John but I have the GME Tug Mounted and more than happy with it. I must add though I turn it off when in large Towns or the City. The rubbish there is not worth putting up with.
May not answer all your questions but "UHF CB Australia" http://www.uhfcb.com.au/ is a wealth of information on matters UHF
Merda tauris scientia vincit
Howdy John,
I have a Uniden 5 watt 80 channel hand held which clips to my sunvisor while driving. I have external mount to interchange between the 4db gain antenna and the 9db gain. I also have 2 x 1watt handhelds for closer work around the campsite. All can be charged from a USB oulet.
When in the Flinders Ranges last November I got from Hawker to Willow Springs no problem (about 100 kms).
Cheers Glenn
 There is nothing new with this band restructure. I have experienced many of them during my working life. They were all planned so that the new and old equipnent would work together with some limitations.
1. The narrow band equipment gives less volume when received by wide band equipment.
2. Signals from wideband transmitters will splatter across the adjacent narrow band channels. (the bandwidth occupied by wide band equipment is 16 kHz wide which is greater than the 12.5 kHz channel spacing.)
3. The signals from the narrow band transmitters will splatter into the wideband receivers (same reason as 2.)
The problems in 2 & 3 will mostly be when the two receivers are not too far from each other.
Was in the game for a long time, GME are good but I like ICOM!
"If you don't know where you are going, any road will get you there".
 Lewis Carroll
briggspc wrote:
 .....  GME are good but I like ICOM!
 I'd have to agree .. a few years ago I purchased (2) Icom IC 41s handhelds. They probably are dearer, but these have functioned without problems .. It recently cost me $18.00 to have them both (software)  upgraded to current 80 ch standards ..
Jon
  ** living life !! **
