SmartBar Camp Creative
Post Info TOPIC: fly screen
fly screen
I think a while ago some of us was talking about buying the fly screen curtain from Big W that you could adapt to the van doors we have got one have worked on adapting it today but find that the velcro strips are not really strong enough have others found this I know that Dougwe has the same van as ours how did you cope with it Doughwe. Helena.
Is the velcro around the outside? Maybe stronger velcro or magnetic stips to attach to vehicle doorway?
You can get stronger velcro on rolls, from Bunnings, and it is self-adhesive and quite strong.
Transport has no borders.
The velcro is on the inside of the van Chris just inside the doorway put it up this afternoon as a try out and a wind blew the thing off so would need to be pretty strong self adhesive stuff I think unless there is some kind of glue that you can use. Helena.
Hi Helena, I haven't done anything about it yet. I'm thinking of trying to rig up a screen on a hook system so I just hook up when needed and take down when not. A bit of thought and some makeshift coming up.
I have tried the self sticky velcro and kept coming off originally so gave up on that idea.
The Master
I bought a roll of velcro dots from Bunnings for mine. They seem to be a lot stronger than the strips. Only put it up when needed, parked up and sliding door open.
Happy Wanderer
Don't worry, Be Happy!
The Happy Helper
You can get offcuts of magnetic strips from some signwriters - I presume you don't want to leave them on permanently. I have them on my cottage here on the front and back doors, but because they are staying in place I used a hot glue gun to make dots around door frames.
The velcro strips they supply are not strong enough - but you can buy genuine velcro on rolls from Bunnings or Spotlight - make sure it is genuine Velcro brand. Better grip - and wider than that supplied.
jules
(Ben, aged 10)
Oh hello Jules. Nice of you to tear yourself away to join us.
Thanks for the suggestions will have a look in Bunnings tomorrow also will go to spotlight will get it sorted eventually I guess. Helena.
The Happy Helper
 Now, now Granny - whatever do you mean????????????????????????
jules
(Ben, aged 10)
Master (of Mischief)
can I suggets a few 6 inch nail's biggrin
The Master
 NO!!
Happy Wanderer
Happywanderer wrote:
 NO!!
 Bugga, I'll go back in my hole biggrinbiggrin
What's with the new av wombat, do you think you will get some cuddles?
If you think I will give you a cuddle, think again. nonobiggrin
6 inch nails I think not the size our van is we wouldn't have one left. Helena
Called in at Bunning found some Velcro there tht even holds hammers up in the garage it is real heavy duty stuff so am going to give that a try Hope it works. Helena.
I bought some double sided tape, but have not used it yet, still waiting to see if there are any better solutions.
What the heck, why not !
Will let you know how it goes at the moment have niece from England staying with us Helena.
 I always get cuddles. biggrinbiggrin
I have tried the velcro from spotlight there is no problem with the two sides sticking together, the problem is sticking the velcro to the van..........it just doesn't hold onto the aluminium walls, I've tried everything I can think of and have now given up so will be happy to hear if anyone succeeds
Happy & Safe travelling
Gill
Magnetic strip won't work on aluminium, but it will work on camper van steel.
Last resort if you reject the idea of 6 inch nails is teck screws.
Or hang it from a curtain cable along the top of the doorway, and then just velcro it to the sides where it's not under any weight, but just to hold it there so the bugs don't fine their way in.
Who would have thought that a good idea would be so hard to implement. Good luck.
Got this in my daily emails.....magnetic flyscreen...............
http://www.ionenergy.com.au/
Judy
Hi Judy ..
Unfortunately, that site changes the items they are promoting all the time .. so folks might not see what you are referring to ..
Jon
  ** living life !! **
http://www.ionenergy.com.au/products/magnetic-fly-screen-door.html
They're dearer than the ones already referred to Barina.
-- Edited by Sheba on Tuesday 17th of April 2012 07:05:05 PM
Thanks Jon
Try this link anyone interested........
Judy
 Crikey, I paid $10.00 for mine from Cheap as Chips, velcro is holding onto the door frame of caravan, no issues with that but I have added some more velcro dots.
This has been a life saver in Parachilna, the flies are atrocious, so with the screen up, we have less issues than opening the caravan's fly screen door and carrying the fly in on your back.
