Post Info TOPIC: Kipor Generator
Kipor Generator
Anyone own or know of kipor GS 2600 generator. I want to run a Colman roof mounted reverse cycle A/C  off it.
http://followpeteraround.blogspot.com.au/
load "kipor GS 2600 generator" into the search area above and I think you will find your answer.
Bob
Bob
Sit, watch and wait.
thanks florinhill seems it will do the job and a bit cheaper than the Honda
Cheaper doesn't mean better.
JC.
your rignt JustCruising but also dearer dosnt mean better either
Scotty01,
Hi They are ok Ive had one for a few years now, and the only problem I had was cracked fuel line.(2 years down the track) It runs the air con. easy and is lite enough to pick up. If you buy a new one RUN it in first or it will burn oil..
I also have the 1000watt. Kipor and its done a lot of hours.....
Bob...
IG2600 Kipor.JPGThis is an older model Kipor rebadged as Genquip 2600. Had it for about 4yrs now with no problems. Has probably had more hours powering our house during long power outages. As Bob said i ran mine for 10hrs with a 1500Watt load to run the motor in first.
D.L.Bishop
